Hi, I need a program to move some selected text to a line something like as extend command but for text objects!
suppose that there is a horizental line (y=constant) or vertical line (x=constant) and some selected text(or other objects), I want a lisp program that move these selected text (or objects) by their "insertion point" to this line.
in other word, if the selected base line is horizental (y=constant) then property of "Y" of all selected text should change to line's "Y"; and if selected base line is vertical (x=constant) then value of "X" of all selected text should match to line's "X" value.
for example, for base vertical line (x=constant) and 3 selected text(or can be any object) result is:
text1. | text1.|
text2. | ===> text2.|
text3. | text3.|
| .text1 |.text1
| .text2 ===> |.text2
| .text3 |.text3
Does anybody have solution?
Solved by Moshe-A. Go to Solution.
the problem is the text insertion point they have Z value
but as you can see the program now ignore it
remember if you will need in future to align text that are at some rotation? you can do it
@aqdam1978 wrote:....
please find the attached, a sample dwg in 2010 version.
[Interestingly, in that particular sample drawing, you can get them aligned the way you want by just Mirroring them [with MIRRTEXT = 0] about a vertical axis. They retain their middle-right justification, and those right-end insertion points are all aligned because the left-end-of-base-line points were aligned in the starting conditions. But it's applicable only to limited circumstances -- I assume from your earlier in-message example that the alignment in the sample drawing would not always be the way things are.]
