the company i work for has changed the function keys in the *.mnl file. i have went in and tried to change the commands back to what they standardly are, but for some reason, CAD isn't accepting the commands. any ideas? below are a couple of examples of what they were and then what i changed them to.
thanks in advance!
(this is what I changed them to)
//["F2"]TEXTSCR;
//["F3"]OSNAP;
//["F4"]PERP;
(this is what i changed them from)
//["F2"]INT;
//["F3"]ENDP;
The "F-Keys" are declared in the MNU/MNS file in the Accelerator division,
and Keyboard Shortcuts - Shortcut Keys section of the CUI file.
I have never seen them declared in the MNL file.
If you need to make changes, and you are using CUI (2006+), look in there
first and do yourself a favor and cancel-out all declarations in the MNL file.
Removing the F-Key declaration in the CUI will restore the key behavior.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
i'm making my changes in the *.mnl file that on my computer. i have changed it before in the same file, but i can't remember why it isn't saving the changes this time.
