Distinguished Contributor
barry2104
Message 1 of 28 (887 Views)
master fillet lisp
887 Views, 27 Replies
12-13-2012 12:36 AM
I'm looking for a lisp which ultimately is a one-stop-shop for filleting and contains the following features/abilities:
1) If i have a polyline in the shape of a P (that is, not a "closed" polyline), I cannot currently use fillet to turn the P into a (closed) D shape. Instead I have to trim, because if i try the fillet command, I need to click on two separate entities and this is a single-entity polyline so it can't work here without a lisp perhaps. Is this possible?
2) I'd like to be able to fillet two lines which have differing z-values. The default fillet command is limited working only when the two filleted elements are in the same plane. An extra query in this lisp asking me "these two elements have different z-values... enter desired z-value for polyline" would be good (though even better if it only asked that when the two elements ARE non-planar, which is only 5% of the time - i.e. ideally I don't get prompted for this every time I fillet, rather, just when the elements aren't in the same plane).
3) normally the resultant polyline assumes the layer of the first selected line, though sometimes (not sure why/when) it plays up and no matter which line i select first, the layer is not the one I want. If this click-priority could be written into the lisp too, that would solve this glitch for me
4) FILLET command only assumes LAYER name & colour, but not global width of the first line/element picked. It would be handy to be able to join the first polyline (global width = 0.5) to a line (no global width) and have the resultant 3-node polyline have a global width of 0.5
5) being able to fillet non-standard elements (e.g. spline) would be a bonus i suppose, but I so rarely use this that it's perhaps not worth the effort. Instead for these cases I could always turn the spline into a polyline (using the FLATTEN command) and then use the regular Fillet command to join them up... though I imagine these steps could be worked into this master-lisp relatively easily?
if anyone knows of a lisp to do this, or has the smarts to create one to integrate as many/all of these asks as possible, that would be amazeballs.
cheers!
Valued Mentor
bgingerich
Message 2 of 28 (846 Views)
Re: master fillet lisp
12-13-2012 12:37 PM in reply to: barry2104
1)  This should work for a "P" to "D" shape.  Not sure if this is what you were looking to do? (untested w/ no error handling)
(defun C::new_fillet (/ ent point1 point2 pl)
	(setq point1 (cdr (setq ent (entsel "\nPick first side to fillet: ")))
		point2 (cdr (entsel "\nPick second side to fillet: "))
		pl (car ent)
	);_ end of setq
	(command "_.pedit" ent "close" "")
	(command "_.fillet" point1 point2)
    (princ) );_ end of defun
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
barry2104
Message 3 of 28 (776 Views)
01-16-2013 03:40 AM in reply to: bgingerich
thanks for the response, but the code doesn't seem to work (at least not for me!).
If anyone else has tips/solutions to integrate as many of the aforementioned functions into the one lisp as possible, I'd love to hear from you!!
Kent1Cooper
Message 4 of 28 (762 Views)
01-16-2013 05:38 AM in reply to: barry2104
Try this adjusted version:
(defun C:new_fillet (/ ent point1 point2 pl); single colon
  (setq
    point1 (cadr (setq ent (entsel "\nPick first side to fillet: "))); point, rather than list containing point
    point2 (cadr (entsel "\nPick second side to fillet: "))
    pl (car ent)
  );_ end of setq
  (princ)
);_ end of defun
EDIT:  HOWEVER, that works only if the P has a line segment at the base of the "loop" part, ending on the "stem" line segment, and if you select on that line segment at the base of the loop, not on the arc segment that loops.  If it's just a vertical stem and an arc segment ending into it, it does close it, but doesn't do what you're looking for.  And if it has the line segment at the base of the loop, but you pick on the arc segment beyond that, it fails because you can't Fillet arc segments in Polylines, and also there will be two intervening segments between the selected ones.
Kent Cooper
barry2104
Message 5 of 28 (758 Views)
01-16-2013 05:47 AM in reply to: Kent1Cooper
Thanks ken, but this still doesn't seem to work either!
I've attached a before & after jpg to show what I effectively want to do. I have an open polyline that I want to fillet to close it. So i type in this magical lisp shortcut and it asks me to pick the two lines to fillet (can be two separate lines/polylines or even both along the same polyline), so i click at the red points 1 and 2.
Then, heypresto, result shown on the right!
^this describes the solution to feature #1... features number 2 and 4 are also of high importance so if either/both of these respective codes/lisps could be worked into the one file that would be rad
any input appreciated!
Kent1Cooper
Message 6 of 28 (743 Views)
01-16-2013 06:08 AM in reply to: barry2104
I've attached a before & after jpg to show what I effectively want to do. ....
It works for me with a P of the right characteristics, but as for you, doesn't work in your illustrated situation.  I suspected at first that it's probably because the closed Polyline that the routine brings about on the way to Filleting is self-intersecting.  But it works [for me] with such a Polyline if there are more than three segments.  Then I guessed that since Fillet with 0 radius on a Polyline works by eliminating one intermediate segment between those picked, in this case it's trying to fillet out the upper-right-edge segment that's intermediate between them in the Polyline's vertex sequence, but because of the directions of things, it can't do that, and it isn't smart enough to look at the other side for a single intermediate segment.  And yet it does work if a three-segment Polyline is not self-intersecting to begin with, in which case it is finding that other-side intermediate segment.  It must be something in the combination of three segments and self-intersection.
If you're always doing this with Polylines of only line segments, I can imagine a way to do it:
Find the crossing point [or virtual crossing point if it isn't already self-intersecting] with the (...intersectwith...) VLA method.
Pedit the Polyline to move its starting vertex to that crossing point, remove its last segment, and close it.
But that won't always give you the right result if there are arc segments involved.
Kent Cooper
Kent1Cooper
Message 7 of 28 (737 Views)
01-16-2013 06:19 AM in reply to: Kent1Cooper
  (setq
    pl (car ent)
  );_ end of setq
And another thing:
(defun C:new_fillet (/ ent point1 point2);;; pl not used); single colon
  (setq
;;;    pl (car ent);;; not used
  );_ end of setq
  (command "_.pedit" ent "close" "");;; or, keep pl variable above and use here in place of ent
  (princ)
);_ end of defun
Kent Cooper
barry2104
Message 8 of 28 (730 Views)
01-16-2013 06:34 AM in reply to: Kent1Cooper
thanks for your efforts Ken, but I think request-function #1 is a lost cause.
Any idea how to crack functions 2 and/or 4 described in the original post?
#2 is effectively giving both entities a z-value of zero before applying the fillet (in case they weren't already at z=0)
#4 is to do a match-properties from the first entity to the second (including global width etc) as it gets filleted
Kent1Cooper
Message 9 of 28 (722 Views)
01-16-2013 07:42 AM in reply to: barry2104
Not so fast....
The following works at the moment only for a 3-segment-only line-segment-only lightweight-only Polyline, which in that case you need to select only once, and it closes it whether self-intersecting as in your image or not.  Compensations can be made for other possibilities ["heavy" 2D or 3D Polylines, more than 3 segments, etc.], but the principle is there.
(defun C:FF (/ plent plobj vertc intc vertpt vertpts intpt done)
  (setq
    plent (car (entsel "\nSelect open Polyline to fillet/close: "))
    plobj (vlax-ename->vla-object plent)
    vertc (safearray-value (variant-value (vla-get-Coordinates plobj))); VERTex Coordinates
    intc (safearray-value (variant-value (vla-IntersectWith plobj plobj acExtendBoth))); INTersection Coordinates
      ; for both on same Pline; includes intermediate vertices but not ends
  ); setq
  (repeat (/ (length vertc) 2); number of VERTex Coordinate lists FOR LWPolyline ONLY [XY coordinates only]
    (setq
      vertpt (list (car vertc) (cadr vertc)); first [remaining] point
      vertpts (cons vertpt vertpts); list of those points
      vertc (cddr vertc); remove first point's coordinates for next one
    ); end setq
  ); end repeat
  (while (not done)
    (setq intpt (list (car intc) (cadr intc))); first remaining point [XY only]
    (if (member intpt vertpts); it's an intermediate vertex
      (setq intc (cdddr intc)); then -- remove first point's coordinates [XYZ] for next one
      (setq done T); else -- it's the [possibly virtual] self-intersection; end (while) loop, keep intpt variable
    ); if
  ); while
  (command "_.pedit" plent "_edit" "_move" intpt "" "" "_break" "" "_go" "_exit" "_close" "");;;;; 3-segment ONLY
  (princ)
); defun
Kent Cooper
Kent1Cooper
Message 10 of 28 (694 Views)
01-16-2013 02:19 PM in reply to: barry2104
barry2104 wrote:
5) being able to fillet non-standard elements (e.g. spline) would be a bonus ....
It may vary by version, but even back in my ol' 2004, Fillet will accept a Spline as long as what it needs to do with it is trim an end off.  It won't extend an end to meet some other object, probably because of the impossibility of deciding where to go with the virtual intersection point, since Splines run on irregular routes.  That would also make it hard for a routine to come up with a place to extend an end to, but one could incorporate Trim to do what regular Fillet does.  Filleting that way won't join the Spline to whatever else, but will leave it as a Spline, so there's no approximating as would be necessary if it's converted to a Polyline.
However, there certainly are still "non-standard elements" [in the sense that regular Fillet refuses to have anything to do with them] that you might want to be able to do something with, such as 3D Polylines or Multilines.  A routine could certainly be made to work with those, at least within certain limits.
Kent Cooper
You are not logged in.
Ask the Community
