is there a way, after inserting a dynamic block, to make one of the stretch grips
active programatically.
TIA
m
Hi
something like this?
(command "insert" "BlockName" pause 1 1 0) (setq ss (ssadd)) (setq ss (ssadd (entlast) ss)) (sssetfirst nil ss)
Cheers
Moshe
correct and nice,
but i was wondering if there was a way to make a specific grip on that object hot (red hot selected)
thanks
You didn't specify your goal so i now presume that you want to progamaticlly set a dynamic block?
search here for (vla-getDynamicBlockProperties) function and you will find alot on it.
Cheers
Moshe
Did you ever figure this out. I would like to make a leader like dynamic block that would have the insert point at the arrow and then make the stretch grip active to see you drag the note to the desired locaiton.
