Hi!
I was searching around and I found this post that is very similar with a doubt that I have.
Does anyone knows how can I remove the first and last dashes that are lengthened to outside of the complex linetype??
Thanks!
@Anonymous wrote:....
AutoCAD complex linetypes always fill out the ends, beyond full linetype-definition cycles, with continuous end segments. To get rid of those, the only thing you can do is to shorten or increase the length of the Line/Arc/Polyline/whatever, so that it is as close as you can get it to a multiple of the length of the definition cycle. If you use Stretch or grips to dynamically adjust the length, you can watch the continuous end segments lengthen and shorten, and pop back to a longer length if you shorten them past zero.
EDIT: Another possibility, if it doesn't adversely affect the graphic result in some other way, is to fine-tune the linetype scale of the object. That at least keeps the endpoints where you drew them, which could often be important. But you may not want to do that with something where the plotted width of the linetype matters, such as batt insulation with a specific thickness, or flexible ductwork with a specific diameter.
OK thanks for answering. I expected something else that involves less time and effort.
I'll try just the way you said. Thanks for the explanation, it is very usefull for me!!
