Visual LISP, AutoLISP and General Customization
list sorting
4 REPLIES 4
southie
324 Views, 4 Replies
list sorting
Hey Gang
Is it possible to sort the below list so that it is sequencial i.e.  "ID NO. 1" "ID NO.2" .....
("ID No. 1" "ID No. 10" "ID No. 11" "ID No. 12" "ID No. 13" "ID No. 14" "ID No. 5" "ID No. 6" "ID No. 7" "ID No. 8" "ID No. 9" "ID No. 2" "ID No. 3" "ID No. 4")
tia
Southie
4 REPLIES 4
southie
in reply to: southie
Found this on the search board thanks kent Cooper. I made a slight modification
(vl-sort
  '("ID No. 1" "ID No. 10" "ID No. 11" "ID No. 12" "ID No. 13" "ID No. 14" "ID No. 5" "ID No. 6" "ID No. 7" "ID No. 8" "ID No. 9" "ID No. 2" "ID No. 3" "ID No. 4")
  '(lambda (a b)
      (atoi (substr a (+ (vl-string-position (ascii " ") a 0 T) 2)))
      (atoi (substr b (+ (vl-string-position (ascii " ") b 0 T) 2)))
  ); lambda
); vl-sort
pbejse
Another
(vl-sort lst
 '(lambda (a b / x)
    	(setq x (vl-string-mismatch a b))
    (< (atoi (substr a x))(atoi (substr b x))
southie
pb thanks for the response learning that '(lambda (a b)... is a friend !!
Southie
devitg
in reply to: pbejse
Thanks , nice routine , I had never seen the
vl-string-mismatch
”Boost
