Hi all,
I’m having a mental collapse\ blank today. I'm trying to write a lisp that toggles between two custom lisp/ functions.
just incase, the lisp is to be incorperated into a button...
Can somebody help?
Solved by stevor. Go to Solution.
Not sure what you mean,
but an easy coding method to toggle between
two anything is use one autolisp variable as a key,
containing either T or nil. Ex:
(if togvar1
(progn (do-one-thing ) (setq TogVar1 nil) )
(progn (do-other-thing ) (setq TogVar1 t ) )
And it could be simplified various ways, but memory and speed is cheap..
And for toggleing between two alternate functions, like Func1 and Func2:
(if TogVar1 ( Func1 ) ( Func2 ) ) ; alternate functions
(setq TogVar1 ( not TogVar1 ) ) ; the toggle of the key
And by using an integer instead of the logic data in the key's state variable,
it can be extended to 3 or more states, and their associated processes, or functions.
thanks this helped...
(defun C:TOGGEL () (if togvar1 (progn (TOMMY) (setq TogVar1 nil) ) (progn (TUCKER) (setq TogVar1 t ) ) ) ) (defun TOMMY () (alert "TOMMY!") ;Sets the next toggel command in place... (setq TogVar1 t ) ) (defun TUCKER () (alert "TUCKER!") ;Sets the next toggel command in place... (setq TogVar1 nil) )
ofcause this is just a test to the entier lisp.
Another option to avoid the global variable:
(defun c:toggle nil (tommy)) (defun tommy nil (alert "Tommy!") (defun c:toggle nil (tucker)) (princ) ) (defun tucker nil (alert "Tucker!") (defun c:toggle nil (tommy)) (princ) )
