lisp to offset the irregular polygon
4 REPLIES 4
sudarsann
1092 Views, 4 Replies
Attachment drawing file having the irregular polygon.
Can any one help how can I get the offset that polygon to inside using lisp.
I prepared a lisp routene for that but it is working when that polygon starting point at lower left of that polygon only.
Please guide me.
4 REPLIES 4
3wood
in reply to: sudarsann
A successful routine to do such task may need includes following features:
1. It is able to find the maximum offset distance for a given closed polyline.
2. It is able to verify whether a given point is inside or outside the polyline.
Then you can generate the new polyline with a certain distance offset from the given polyline.
dicra
Hi sudarsann,
Can you upload, the routine whic you prepared?
Kent1Cooper
Search this Forum and I think you'll find something.  [I'm at a painfully slow computer right now, or I'd look myself.]  One approach I think I recall is a routine to Offset the Polyline in both directions [using (vla-offset) with positive and negative values], compare the areas of the two resulting Polylines, and keep only the smaller one.
Kent Cooper, AIA
Kent1Cooper
in reply to: Kent1Cooper
@Kent1Cooper wrote:
Search this Forum and I think you'll find something.  ....
For instance, this thread.
Kent Cooper, AIA
”Boost
