The function
(setq pa2 (command "_circle" "0,0" "6"))
is going to set the 'pa2' variable to nil, because that is what (command) functions always return.
It is not going to make that (command) function happen when you call for 'pa2' later on. You would
need to (defun) pa2 or some such thing.
Kent Cooper
wrote...
now i have 1 simple error that is stopping me from finishing my lisp routine, it goes like this
( setq pa2 (command "_circle" "0,0" "6"))
