I have read a bunch of posts on this, and I am curious about the following:
I've created a couple of programs:
One - that will start a new project file, add our standard drawing sheets
two - Insert a bunch of wblocked components based on user input
programs 3 - 6 all do the same as program 2, just different components for different sheets.
I can run all these programs and they work (i need to do a lot of "clean-up" but they work)...
I have them set-up to open the next drawing.
But i have to type in the next command, and continue until all my programs and done running.
My questions is how can I accomplish this without having to continually type in commands?
I can't run these as a script, but is there another method?
Solved by Lee_Mac. Go to Solution.
Since AutoLISP runs in the document namespace (Not sure what a namespace is? See here), any active AutoLISP program will cease evaluation when another drawing becomes the active drawing, therefore an AutoCAD Script would be required to open each drawing and load & evaluate the required programs, before saving & closing the drawing and repeating this process across multiple drawings.
The technique that I would recommend for batch processing of drawings is described here.
@gcsjlewis wrote:I can't run these as a script
Why not?
@gcsjlewis wrote:
Do you know of a good place to start with a batch file...this is new to me
I never suggested a batch file
