I have a routine that works the way i want but need to add a function that will also change the text (attributes, mtext, text) style to simplex. I have and old routine that will do that but am not sure how to incorporate it into my lisp.
;;;Routine will rename selected block and edit to change entities to layer 0 and color to bylayer. Would like to add change all text to simplex.
(defun c:RB (/)
(vl-load-com)
(setq obj (vlax-ename->vla-object (car (entsel "Select block: ")))
Eblkname (vlax-get obj 'Effectivename)
Nblkname (strcat (vlax-get obj 'Effectivename) "-ex")
(prompt (strcat "\n\nDynamic block " Eblkname "\nhas been renamed to: " Nblkname "\n"))
(command "_.rename" "b" Eblkname Nblkname)
(command "-bedit" nblkname)
(command "change" "all" "" "p" "la" "0" "p" "c" "bylayer" "" "")
;INSERT CHANGE TEXT STYLE HERE
(command "bclose" "s")
(princ)
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;Global Text Change;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:GT ()
(setq S1 nil) (gc) ; Clear Selection set for use.
(prompt "\nSelect text objects:") ; Will already be selected
(setq S1 (ssget))
(ss-sieve S1 "TEXT") ; Utility routine from Listing 2.
(setq User "Go")
(while (/= User "Exit")
(setq User
(strcase
(getstring "\nChange: Style/Height/Oblq angle/Rot angle/ <eXit>:"))) ;All I need is Style
(if (> (strlen User) 1) (setq User (substr User 1 1)))
(cond
((and (/= User "X") (/= User ""))
(setq Code
(cond
((= User "S") 7)
((= User "H") 40)
((= User "O") 51)
((= User "R") 50)
(t nil)))
(cond
((boundp 'Code)
(setq New (getstring "\nNew value:")); simplex
(if (> Code 20) (setq New (atof New)))
(if (and (> Code 49) (< Code 60))
(setq New (* (/ New 180.0) pi)))
(setq CNT -1)
(repeat (sslength S1)
(setq Elist (entget (ssname S1 (setq CNT (1+ CNT)))))
(entmod
(cond
((null (assoc Code Elist))
(append Elist (list (cons Code New))))
(t
(subst (cons Code New) (assoc Code Elist) Elist)
)))))(t (prompt "\nEntry invalid:"))))(t
(setq User "Exit")))))
(defun ss-sieve (S1 Screen)
(setq CNT (sslength S1))
(while (> CNT 0)
(setq Elist (entget (ssname S1 (setq CNT (1- CNT)))))
(cond
((/= (cdr (assoc 0 Elist)) Screen)
(ssdel (ssname S1 CNT) S1)))))
Hi Traci,
You will need the "vla-put-stylename" to update the text style of the attribute.
Have you tried the code from this discussion thread ?
Balaji
Thanks, I found an old command called _optchprop that does what I want without any "real" code.
Thanks.
