i know DIMANGULAR command will let me draw a dimension to display the angle between two lines, but is there a way for my commandbar to show me what the angle is rather than draw a dimension?
I often want to simply know the angle but not display it in the drawing, and it'd be good if there was a command/lisp which showed me in the commandline area, or perhaps a pop up window, similar to what the TLEN lisp does here:
www.turvill.com/t2/free_stuff/tlen.lsp
any help appreciated
Solved by Kent1Cooper. Go to Solution.
Solved by pbejse. Go to Solution.
Solved by Lee_Mac. Go to Solution.
@stevesfr wrote:Kent, thank you so much ! ! !
Steve
You're welcome. It may be a little over-capable -- who would ever really want to know the angle between an Image outline and a Tolerance box? But having established generic ways to determine the angle certain kinds of things run at, I just went ahead and applied them to anything I could determine that they could be applied to [basically, vlax-curve-qualified things and any other Osnappable things], even if that covers more possibilities than are really very likely. The nested-object capability is certainly of more practical value than that range-of-weird-entity-types aspect, and was in fact a major part of the impetus to develop the Bisector routine in the first place.
Hey Kent, can you edit the ReportAngle lisp to find angle between adjacent arc type object and line type object?
@vikrambest1 wrote:
.... to find angle between adjacent arc type object and line type object?
Since the direction of an "arc type object" varies continuously, I assume you mean the angle between the straight thing and the curved thing at the point where they intersect:
Is that correct?
I want Lisp to export the results of measuring the angle between a straight line in CAD 3D and the XOY plane and the angle between that line and the X axis to excel. Thank you
