layout selection... error
5 REPLIES 5
hcanas
508 Views, 5 Replies
I GOT the following error on a lisp that will check if a plot device is assigned to the layout --- what i doing wrong, please help...
it get me only the first layout and get canceled.....
(vl-load-com)
;; Get the current drawing
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq lstLayouts nil
        arSize 0)
;; CustomPageSetup ==================
(vlax-for *layout* (vla-get-layouts doc)
;; Check to see if a plot device is assigned to the layout, if not it will not be plotted
(if (and (/= (strcase (vla-get-ConfigName *layout*)) "NONE")
            (= (vla-get-ModelType *layout*) :vlax-false)
(progn
(if (= lstLayouts nil)
    (setq lstLayouts (list (vla-get-Name *layout*)))
    (setq lstLayouts (append lstLayouts (vla-get-Name *layout*))) ; <== ERROR... i got only the first layout and canceled....
DC
5 REPLIES 5
hmsilva
in reply to: hcanas
Change
to
(setq lstLayouts (cons (vla-get-Name *layout*)lstLayouts))
HTH
Henrique
Gary_J_Orr
in reply to: hcanas
(vl-load-com)
        arSize 0)
(progn
While Henrique is pointing you to another solution here is where your original attempt tripped on itself:
you didn't convert the second (and any following) layout name to a list for the append function to work with (it requires multiple lists):
    (setq lstLayouts (append lstLayouts (list (vla-get-Name *layout*)))) ; <== ERROR... i got only the first layout and canceled....
-Gary
Gary J. Orr
(Your Friendly Neighborhood) CADD/BIM/VDC Applications Manager
http://www.linkedin.com/in/garyorr
aka (current and past user names):
Gary_J_Orr (GOMO Stuff 2008-Present); OrrG (Forum Studio 2005-2008); Gary J. Orr (LHB Inc 2002-2005); Orr, Gary J. (Gossen Livingston 1997-2002)
hcanas
in reply to: hmsilva
thank
DC
hcanas
in reply to: Gary_J_Orr
thank you for the clarification Gary.... now i got it..
DC
hmsilva
in reply to: hcanas
@hcanas wrote:
thank  @hmsilva
You're welcome, hcanas!
Henrique
”Boost
