Hi all,
is there any lisp that can help with my issue below:
best
Jamal
Jamal,
What the kind of sort the objects coordinates you want to display??
You can insert fields into table but not for all object types
~'J'~
Thanks Hallex for the answer.
what i need is list the XYZ obtained from the command "list" in a table in the AutoCAD as shown in the screenshot below
best
Jamal
Jamal,
You can try my program from post #9 in there:
~'J'~
In addition try this too:
{code}
(defun C:demo(/ acsp adoc col dimz ip pt row tbl txt x y z)
(setq adoc (vla-get-activedocument (vlax-get-acad-object))
acsp (vla-get-block (vla-get-activelayout adoc))
(setq dimz (getvar "dimzin"))
(setq ip (getpoint "\n Table Location Point: "))
(setvar "dimzin" 0)
(setq tbl (vla-addtable
acsp
(vlax-3d-point ip)
2
3
(* (getvar "dimtxt") 2)
(* (strlen (rtos (car ip) 2 3)) (getvar "dimtxt"))
;(vla-put-regeneratetablesuppressed tbl :vlax-true)
(vla-SetText tbl 0 0 "Coordinate Table")
(setq row 1)
(mapcar '(lambda (col txt) (vla-SetText tbl row col txt))
(list 0 1 2)
(list "X coord." "Y coord." "Z coord.")
(while
(setq pt (getpoint "\nPick a Point: "))
(setq x (rtos (car pt) 2 3)
y (rtos (cadr pt) 2 3)
z (rtos (caddr pt) 2 3)
(setq row (1+ row))
(vla-InsertRowsAndInherit tbl row (- row 1) 1)
(mapcar '(lambda (col txt) (vla-SetText tbl row col txt)) (list 0 1 2) (list x y z))
;(vla-put-regeneratetablesuppressed tbl :vlax-false)
(setvar "dimzin" dimz)
(princ)
{code}
~'J'~
Thank you guys for the help.
I could extract the coordinates of the points in the light of the help i recieved from Alfred. please, have a look on the link below:
best
Jamal
If you want, try this?
(vl-load-com) (defun c:points2cell ( / js AcDoc Space all_path j end_pos id_path fonts_path file_shx nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n obj dxf_10 nb nw_obj ename_cell n_row n_column) (princ "\nSelect points.") (while (null (setq js (ssget '((0 . "POINT"))))) (princ "\nSelection empty, or is not a point!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (cond ((null (tblsearch "LAYER" "Table-Points")) (vla-add (vla-get-layers AcDoc) "Table-Points") ) ) (cond ((null (tblsearch "STYLE" "Text-Cell")) (setq all_path (getenv "ACAD") j 0) (while (setq end_pos (vl-string-position (ascii ";") all_path)) (setq id_path (substr all_path 1 end_pos)) (if (wcmatch (strcase id_path) "*FONTS*") (setq fonts_path (strcat id_path "\\")) ) (setq all_path (substr all_path (+ 2 end_pos))) ) (setq file_shx (getfiled "Select a font file " fonts_path "shx" 8)) (if (not file_shx) (setq file_shx "txt.shx") ) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list file_shx 0.0 (/ (* 15.0 pi) 180) 1.0 0.0) ) (command "_.ddunits" (while (not (zerop (getvar "cmdactive"))) (command pause) ) ) ) ) (setq oldim (getvar "dimzin") oldlay (getvar "clayer") ) (setvar "dimzin" 0) (setvar "clayer" "Table-Points") (initget 9) (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: ")) (initget 6) (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: "))) (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t)) (initget 7) (setq w_c (getdist ins_pt_cell "\nWidth of cells: ")) (setq lst_id-seg '() lst_pt '() nb 0 ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) dxf_10 (cdr (assoc 10 (entget obj))) lst_pt (cons dxf_10 lst_pt) nb (1+ nb) lst_id-seg (cons nb lst_id-seg) ) ) (mapcar '(lambda (p tx) (setq nw_obj (vla-addMtext Space (vlax-3d-point p) 0.0 tx ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation) (list 5 h_t 5 p "Text-Cell" "Table-Points" 0.0) ) ) lst_pt lst_id-seg ) (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 3 (+ h_t (* h_t 0.25)) w_c) (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1) (vla-SetCellValue ename_cell 0 0 (vlax-make-variant (strcat "Summary of " (itoa (sslength js)) " POINTS") 8 ) ) (vla-SetCellTextStyle ename_cell 0 0 "Text-Cell") (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5)) (vla-SetCellAlignment ename_cell 0 0 5) (foreach n (mapcar'list (append lst_id-seg '("N°")) (append (mapcar 'rtos (mapcar 'car lst_pt)) '("Coordinates X")) (append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("Coordinates Y")) ) (mapcar '(lambda (el) (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column)) (if (or (eq (rtos 0.0) el) (eq (angtos 0.0) el)) (vlax-make-variant "_" 8) (vlax-make-variant el 8)) ) (vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell") (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5)) (if (eq n_row 1) (vla-SetCellAlignment ename_cell n_row n_column 5) (vla-SetCellAlignment ename_cell n_row n_column 6) ) ) n ) (setq n_row (1- n_row) n_column -1) ) (setvar "dimzin" oldim) (setvar "clayer" oldlay) (prin1) )
