• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Active Member
    importing coord. from excel to draw lines
    60 Views, 3 Replies
    02-08-2003 03:17 AM
    i have approx 4,000 pairs (help!!) of coordinates (x,y & z) in an excel document, each pair representing a line. i'm supposed to draw these lines in acad. lisp-beginner's question: (if this is even possible) can anyone help me with a lisp routine that imports the coordinates from the excel document into acad, and draws the lines for me? grateful for any input!
    Please use plain text.
    *Broad, Doug
    Re: importing coord. from excel to draw lines
    02-08-2003 06:02 AM in reply to: cadlabrat
    Although you can interface excel directly with
    autocad, it is not beginners
    territory.  For ease of implementation, I
    suggest:
    1.  Save the worksheet as text in
    the csv format.
    2.  Close excel and rename the file to have an
    scr extension
    3.  Drag it into notepad or
    wordpad.
    4.  Add the word LINE or PLINE at the
    top.  Add a blank line at the bottom. Save.
    5.  In autocad, enter script and choose your
    new script file.  Voila.  The
    lines are drawn
    If you do this a lot and want a canned application,
    drop me a line and
    we'll discuss it.
    Doug
    have
    input!
    *van Rij, w.k.m.
    02-09-2003 12:17 AM in reply to: cadlabrat
    Try this:
    The path to the Excel file was hard coded. Adapt as required
    for the start points:
    X- values are assumed in column 'A', Y values in 'B', Z in column 'C'
    for the end points:
    X- values are assumed in column 'D', Y values in 'E', Z in column 'F'
    The routine stops at the first blank cell in the 'A' column.
    (defun c:excel-lines (/ getcoords ms XL xlBook s-e)
    (vl-load-com)
    (defun getcoords (Sheet row /)
    (if (vlax-get (vlax-get-property Sheet 'Range (strcat "A" (itoa row)))
    'Value
    ) ;_ end of vlax-get
    (list
    (vlax-3d-point
    'Value
    (vlax-get (vlax-get-property Sheet 'Range (strcat "B" (itoa row)))
    'Value
    (vlax-get (vlax-get-property Sheet 'Range (strcat "C" (itoa row)))
    'Value
    ) ;_ end of vlax-3d-point
    (vlax-3d-point
    (vlax-get (vlax-get-property Sheet 'Range (strcat "D" (itoa row)))
    'Value
    (vlax-get (vlax-get-property Sheet 'Range (strcat "E" (itoa row)))
    'Value
    (vlax-get (vlax-get-property Sheet 'Range (strcat "F" (itoa row)))
    'Value
    ) ;_ end of list
    ) ;_ end of if
    ) ;_ end of defun
    (and (setq ms (vlax-get (vla-get-activedocument (vlax-get-acad-object))
    'ModelSpace
    ) ;_ end of setq
    (or
    (setq XL (vlax-create-object "Excel.Application"))
    (alert "Could not load Excel. Sorry")
    (exit)
    ) ;_ end of or
    (not (vlax-put XL 'Visible :vlax-true))
    ;;(not (vlax-put XL 'ReferenceStyle 1))
    (or (setq xlBook (vlax-invoke (vlax-get XL 'Workbooks)
    'Open
    "C:\\My documents\\coords.xls" ;; Or whereever your Excel file
    resides
    ) ;_ end of vlax-invoke
    ) ;_ end of setq
    (alert "Could not load the Excel file. Sorry to quit")
    ) ;_ end of or
    (setq row 1
    xlSheet (vlax-get xlBook 'ActiveSheet)
    ) ;_ end of setq
    (while (setq s-e (getcoords xlSheet row))
    (vlax-invoke-method
    ms
    'AddLine
    (car s-e)
    (cadr s-e)
    (setq row (1+ row))
    ) ;_ end of while
    ) ;_ end of and
    (vlax-invoke-method XL 'Quit)
    ) ;_ end of defun
    cadlabrat schreef in berichtnieuws
    f141bd1.-1@WebX.maYIadrTaRb...
    Active Member
    02-09-2003 01:16 AM in reply to: cadlabrat
    w.k.m.van Rij, Doug - Thank you both for your input! although i'm at work (yes, i know it's sunday!) i can't access the specific excel file until tomorrow. i will, however, make an attempt at solving my "problem" first thing monday using your input - we'll see how it goes...might still need advice.
    Magnus Palmgren
