(defun c:duct(/ actDoc Ang1 Ang2 ptLst enDist fPt lEnt lObj lPln oldVars oldWd plEnd plStart1 plStart2 prDir segLst Start stDist stLst tAng vlaPln *error*) (command "-layer" "m" "V-VK" "C" "RED" "" "LT" "CONTINUOUS" "" "" "") (command "-layer" "set" "V-VK" "") (vl-load-com) (defun GetPlineVer(plObj) (mapcar 'cdr (vl-remove-if-not '(lambda(x)(=(car x)10)) (entget plObj))) ); end of GetPLineVer (defun asmi-PlineSegmentDataList(plObj / cLst outLst) (setq cLst (vl-remove-if-not '(lambda(x)(member(car x) '(10 40 41 42))) (entget plObj)) outLst '() ); end setq (while cLst (if(assoc 40 cLst) (progn (setq outLst (append outLst (list (list (cdr(assoc 10 cLst)) (cdr(assoc 40 cLst)) (cdr(assoc 41 cLst)) (cdr(assoc 42 cLst)) ); end list ); end list ); end if ); end setq (repeat 4 (setq cLst(cdr cLst)) ); end repeat ); end progn (setq outLst (append outLst (list (list (cdr(assoc 10 cLst)) ); end list ); end list ); end append cLst nil ); end setq ); end if ); end while outLst ); end of asmi-GetPlineSegmentData (defun asmi-LayersUnlock(/ restLst) (setq restLst '()) (vlax-for lay (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq restLst (append restLst (list (list lay (vla-get-Lock lay) (vla-get-Freeze lay) ); end list ); end list ); end append ); end setq (vla-put-Lock lay :vlax-false) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Freeze(list lay :vlax-false))) t) ); end vlax-for restLst ); end of asmi-LayersUnlock (defun asmi-LayersStateRestore(StateList) (foreach lay StateList (vla-put-Lock(car lay)(cadr lay)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Freeze(list(car lay)(nth 2 lay)))) t) ); end foreach (princ) ); end of asmi-LayersStateRestore (defun PipeMLineStyle(/ dxfLst mlDict) (setq dxfLst (list'(0 . "MLINESTYLE")'(102 . "{ACAD_REACTORS")'(102 . "}") '(100 . "AcDbMlineStyle") '(2 . "DUCT_PIPE") '(70 . 272)'(3 . "")'(62 . 256)'(51 . 1.5708)'(52 . 1.5708) '(71 . 2)'(49 . 0.5)'(62 . 256)'(6 . "BYBLOCK") '(49 . -0.5)'(62 . 256)'(6 . "BYBLOCK"))); end setq (if (null (member (assoc 2 dxfLst) (dictsearch (namedobjdict) "ACAD_MLINESTYLE"))) (progn (setq mlDict (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_MLINESTYLE")))) (dictadd mlDict (cdr(assoc 2 dxfLst))(entmakex dxfLst)) ); end progn ); end if ); end of PipeMLineStyle (defun *error*(msg) (setvar "CMDECHO" 0) (if lObj (command "_.erase"(entnext lObj)"") (command "_.erase"(entlast)"") ); end if (if oldVars (mapcar 'setvar '("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE") oldVars); end mapcar ); end if (if stLst (asmi-LayersStateRestore stLst) ); end if (if actDoc (vla-EndUndoMark actDoc) ); end if (princ "*Cancel* ") (princ) ); end of *error* (PipeMLineStyle) (if(not dpipepWd)(setq dpipepWd 1.0)) (setq oldWd dpipepWd dpipepWd(getdist (strcat "\nSpecify first segment width <" (rtos dpipepWd) ">: ")) oldVars(mapcar 'getvar '("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE")) ); end setq (if(null dpipepWd)(setq dpipepWd oldWd)) (mapcar 'setvar '("FILLMODE" "PLINEWID" "CMDECHO") (list 0 dpipepWd 1)); end mapcar (if(entlast)(setq lObj(entlast))) (vla-StartUndoMark (setq actDoc (vla-get-ActiveDocument (vlax-get-acad-object)))) (setq fPt (getpoint "\nSpecify start point: ") ); end setq (command "_.pline" fPt) (while(= 1(getvar "CMDACTIVE")) (command pause) ); end while (if (not (equal lObj(entlast))) (progn (setq lEnt(entlast) stLst(asmi-LayersUnlock) segLst(asmi-PlineSegmentDataList lEnt) vlaPln(vlax-ename->vla-object lEnt) ); end setq (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (while (/= 1(length segLst)) (setq stDist (vlax-curve-getDistAtPoint vlaPln (caar segLst)) enDist (vlax-curve-getDistAtPoint vlaPln (caadr segLst)) ); end setq (if(< 2(length segLst)) (setq ang1 (+(/ pi 2)(angle(caar segLst)(caadr segLst))) ang2 (+(/ pi 2)(angle(caadr segLst)(car(nth 2 segLst)))) ); end setq ); end if (if (or (not Start) prDir );end or (setq plStart1 (vlax-curve-getPointAtDist vlaPln stDist) Start T); end setq (setq plStart1 (vlax-curve-getPointAtDist vlaPln (+ stDist(cadar segLst)))); end setq ); end if (if (or (equal ang1 ang2 0.000001) (= 2(length segLst)) ); end or (setq plEnd (vlax-curve-getPointAtDist vlaPln enDist) prDir T); end setq (setq plEnd (vlax-curve-getPointAtDist vlaPln (- enDist(cadar segLst))) prDir nil); end setq ); end if (if (< 2(length segLst)) (setq plStart2 (vlax-curve-getPointAtDist vlaPln (+ enDist(cadar segLst)))); end setq ); end if (if(< 2(length segLst)) (if (=(cadar segLst)(nth 2(car segLst))) (setq ptLst (mapcar '(lambda(x)(trans x 0 1)); end lambda (list(polar plEnd ang1 (/(cadar segLst)2)) (polar plEnd (+ pi ang1)(/(cadar segLst)2)) (polar plStart2 (+ pi ang2)(/(cadar segLst)2)) (polar plStart2 ang2 (/(cadar segLst)2)) ); end list ); end mapcar ); end setq (setq ptLst (mapcar '(lambda(x)(trans x 0 1)); end lambda (list (polar plStart1 ang1 (/(cadar segLst)2)) (polar plStart1 (+ pi ang1)(/(cadar segLst)2)) (polar(caadr segLst)(+ pi ang2)(/(nth 2(car segLst))2)) (polar(caadr segLst)ang2(/(nth 2(car segLst))2)) ); end list ); end mapcar ); end setq ); end if ); end if (setq plStart1(trans plStart1 0 1) plEnd(trans plEnd 0 1) ); end setq (if plStart2 (setq plStart2(trans plStart1 0 1)) ); end if (if (or (not(equal ang1 ang2 0.000001)) (/=(cadar segLst)(nth 2(car segLst))) ); end or (progn (setvar "PLINEWID" 0.0) (command "_.pline") (mapcar 'command ptLst)(command "_c") (setvar "PLINEWID" dpipepWd) ); end progn ); end if (if (not(equal ang1 ang2 0.000001)) (progn (setq lPln (vlax-ename->vla-object(entlast)) tAng(- ang2 ang1) ); end setq (if(minusp tAng)(setq tAng(- tAng))) (if (and (< 0 tAng) (>= pi tAng) ); end and (progn (vla-SetBulge lPln 1 (/(- ang2 ang1)4)) (vla-SetBulge lPln 3 (/(- ang1 ang2)4)) ); end progn (progn (vla-SetBulge lPln 1(/(- ang1 ang2)12)) (vla-SetBulge lPln 3(/(- ang2 ang1)12)) ); end progn ); end if ); end progn ); end if (if (=(cadar segLst)(nth 2(car segLst))) (command "_.mline" "_st" "DUCT_PIPE" "_S" (cadar segLst) "_J" "_Z" plStart1 plEnd "") ); end if (setq segLst(cdr segLst)); end setq ); end while (command "_.erase" lEnt "") (asmi-LayersStateRestore stLst) ); end progn ); end if (vla-EndUndoMark actDoc) (mapcar 'setvar '("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE") oldVars); end apply (princ) ); end of c:dpipe ;FC FILLET WITH SPECIFIED RADIUS (defun C:FC () (command "FILLET" "RADIUS" 6 "FILLET") (princ) )
