I "stole" the lisp for the flatten command posted below. I am trying to modify it so after it prompts me to select objects, it automatically selects "all", and then when it prompts me if I want to remove hidden lines, it automatically does. I tried this
(defun c:fl () (command "flatten" "all" "yes")) as well as
(defun c:fl () (c:flatten "all" "yes"))
but this will not recognize any input after flatten. I can manually type them in, but I can't get the lisp to automatically do it. So I chose to modify the flatten lisp itself (FYI this is an express lisp if that matters)
(defun c:fl ( / ss ans ) (acet-error-init (list nil 1)) (princ "\nSelect objects to convert to 2d...") (if (not acet:flatn-hide) (setq acet:flatn-hide "No") );if (if (and (setq ss (ssget "_:l" '((-4 . "<NOT") (0 . "VIEWPORT") (-4 . "NOT>"))));setq (setq ss (car (acet-ss-filter (list ss nil T)))) );and (progn (initget "Yes No") (setq ans (getkword (acet-str-format "\nRemove hidden lines? <%1>: " acet:flatn-hide ) );getkword );setq (if (not ans) (setq ans acet:flatn-hide) (setq acet:flatn-hide ans) );if (if (equal ans "No") (acet-flatn ss nil) (acet-flatn ss T) );if );progn then );if (acet-error-restore) );defun c:flatten
(acet-autoload2 '("FLATTENSUP.LSP" (acet-flatn ss hide))) (princ)
manamalewis,
Flatten is not a AutoCAD native command, it is a external function.
As I had already posted in your previous post "select all command in autolisp", using vla-sendcommand, it is possible to send to the command line the answers to the prompts of the function Flatten...
(vl-load-com);; Loads Visual LISP extensions to AutoLISP (defun c:fl ();;select all and don't remove hidden lines (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "flatten all\r no\r") (princ) ) (defun c:fy ();;select all and remove hidden lines (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "flatten all\r yes\r") (princ) )
hope that helps
Henrique
Hi Henrique , Enrique is my second first name , no H .
Wahat do it mean te \r in , is it a carriage return or ENTER??
Gabriel Enrique
Hi Gabriel,
as you can see I have not used the (strcat) function, it is not necessary, so, just a space will do the trick, if you try this string "flatten all yes ",
the command runs as expected, but on the command line, the echon appear without changing lines.
I use \ r to view the line changes while I'm writing code and that the echo is as close as possible to the original command echo.
Cheers
Henrique
