Visual LISP, AutoLISP and General Customization
get tracking point
7 REPLIES 7
Message 1 of 8
andresep82
468 Views, 7 Replies
get tracking point
Hello again!!!
 I am Making an application that inserts blocks in points,It works well but when I select a tracking point, the block is inserted in the point of reference of the tracking, and i  would like that it was inserted in thetracking point
how i am fix it?
sorry for my english level.
thanks¡¡¡
7 REPLIES 7
Message 2 of 8
dbroad
in reply to: andresep82
Show your code.  Do you mean "at point entities" rather than "in points."
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
andresep82
in reply to: dbroad
the code:
(defun C:PUERTAS()
;;;;;CREO LAS CAPAS POR SI NO EXISTEN;;;;;
  (if (not (tblsearch "LAYER" "CARPINTERIA"))
    (command "_.-layer" "_make" "CARPINTERIA" "_color" 2 "" "")
  (if (not (tblsearch "LAYER" "CARPINTERIA_ETIQUETAS"))
    (command "_.-layer" "_make" "CARPINTERIA_ETIQUETAS" "_color" 2 "" "")
(setvar 'clayer "CARPINTERIA"); CAMBIAR A LA CAPA
 ;;;--- Load the dcl file from disk into memory
  (if(not(setq dcl_id (load_dialog "PUERTAS.dcl")))
    (progn
      (alert "The DCL file could not be loaded!")
      (exit)
    ;;;--- Else, the DCL file was loaded
    (progn
      ;;;--- Load the definition inside the DCL file
      (if (not(new_dialog "PUERTAS" dcl_id))
        (progn
        (alert "The prueba definition could not be loaded!")
          (exit)
        ;;;--- Else, the definition was loaded
        (progn
          ;;;--- If an action event occurs, do this function
(defun saveVars()
  ;;;--- Get the value of each item
  (setq choice1(atoi(get_tile "but1")))  ; 0 = not chosen    1 = chosen
  (setq choice2(atoi(get_tile "but2")))  ; 0 = not chosen    1 = chosen
  (setq choice3(atoi(get_tile "but3")))  ; 0 = not chosen    1 = chosen
	(action_tile "accept" "(saveVars)(done_dialog 2)")
        (action_tile "cancel" "(done_dialog 1)")
          ;;;--- Display the dialog box
          (setq ddiag(start_dialog))
          ;;;--- Unload the dialog box
          (unload_dialog dcl_id)
         ;;;--- If the user pressed the Okay button
          (if(= ddiag 2)
            (progn
              (princ "\n Has elegido.... ")
      (cond
        ((= Choice1 1)(princ "62.5x2.03 cm"))
        ((= Choice2 1)(princ "72.5x2.03 cm"))
        ((= Choice3 1)(princ "82.5x2.03 cm"))
      );end if
(princ "\n P1 (Punto de inserción) P2 (dirección)")
(setq ip (getpoint "\n Punto de inserción:   "))
(if
	(= Choice1 1)
		(command "_insert" "E:/BLOQUES/PUERTA.dwg" ip "" "" pause )
		( valor 1)
);end if
(if
	(= Choice2 1)
		( valor 2)
);end if
(if
	(= Choice3 1)
		(command "_insert" "E:/BLOQUES/PUERTA.dwg" ip "" "" pause)
		( valor 3)
);end if
            );end progn
     );end cond
 ;;;--- If the user pressed the Cancel button
	(if(= ddiag 1)
            (princ "\n Saliendo de puertas...")
          );end if
(setq escalax 1)
(setq escalay 1)
(setq bloque (entlast))
  (setdynpropvalue (vlax-ename->vla-object bloque) "ANCHO" valor)
  ;;;--- Suppress the last echo for a clean exit
  (princ)
;;;;; pasar de radianes a grados;;;;;;
(DEFUN rad_sexa (radianes)
  (/  (* radianes 180.0) PI)
;; Set Dynamic Block Property Value  -  Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(defun setdynpropvalue ( blk prp val )
    (setq prp (strcase prp))
    (vl-some
       '(lambda ( x )
            (if (= prp (strcase (vla-get-propertyname x)))
                (progn
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
        (vlax-invoke blk 'getdynamicblockproperties)
;; Get Dynamic Block Properties  -  Lee Mac
;; Returns an association list of Dynamic Block properties & values.
;; Returns: [lst] Association list of ((<prop> . <value>) ... )
(defun getdynprops ( blk )
    (mapcar '(lambda ( x ) (cons (vla-get-propertyname x) (vlax-get x 'value)))
;; Effective Block Name  -  Lee Mac
;; obj - [vla] VLA Block Reference object
(defun effectivename ( obj )
    (vlax-get-property obj
        (if (vlax-property-available-p obj 'effectivename)
            'effectivename
            'name
 menu code:
PUERTAS : dialog {
  label = "INSERTAR PUERTAS";
          : column {
	   : column {
              : text {
                key = "text1";
                 value = "Puertas";
 	: boxed_column {
              label = "Dimensiones:";
            : radio_row {
              key = "choices";
              : radio_button {
                key = "but1";
                label = "62.5x2.03 cm";
              : radio_button {
                key = "but2";
                label = "72.5x2.03 cm";
              : radio_button {
                key = "but3";
                label = "82.5x2.03 cm";
	: radio_row {
              key = "choices1";
	      : radio_button {
                key = "but4";
                label = "Personalizado";
	: edit_box {
                key = "Ancho";
                label = "Ancho(cm)";
                edit_width = 5;
                value = "";
                initial_focus = true;
	: edit_box {
                key = "Alto";
                label = "Alto(cm)";
                edit_width = 5;
                value = "";
	: boxed_column {
              label = "Referencia:";
	    : edit_box {
                key = "Referencia";
                label = "Referencia carpintería";
                edit_width = 5;
                value = "P1";
	: column {
	: button {
                key = "accept";
                label = " Aceptar ";
                is_default = true;
              : button {
                key = "cancel";
                label = " Cancelar ";
                is_default = false;
                is_cancel = true;
		width = 5;
 		height = 1;
 the block:
https://www.dropbox.com/s/ly5z4indjb8n6il/puerta.dwg
if i active reference "Nearby" work but i like selec point using trakerig reference.
and other problem......Why it does not change the variable "valor" ?
Message 4 of 8
dbroad
To make your code more portable, don't hard code the paths.  For example, use
(COMMAND "_insert""PUERTA" ip "" ""  pause) rather than
(COMMAND "_insert""E:/BLOQUES/PUERTA.dwg" ip "" ""  pause)
In your if sequence, I assume you only want to do one choice.  If so, then use COND or if / else constructs instead of a sequence of ifs.
(cond
  ((= choice1 1)
   (COMMAND "_insert" "PUERTA" ip "" "" pause)
   (valor 1)
 ((= choice2 1)
  (valor 2)
(t
(valor 3)
) );end COND
valor wasn't posted so anything other than choice1 fails.
To use tracking, enter TRK or TK before entering the first point.  Use enter to end tracking.
Message 5 of 8
andresep82
in reply to: dbroad
What you want to say with "enter TRK or TK" i dont I understand you.
and.... i know That I have to improve the structure of the code,   Smiley Very Happy  but I am learning.
thanks¡¡¡¡¡¡¡¡¡¡¡¡¡
Message 6 of 8
dbroad
I was responding to your original post:  "... select a tracking point.."
In the english version of AutoCAD tracking is accomplished by entering "tk" or "trk" at a point entry prompt before picking a point.  It allows you to take a taxi cab route to your destination from a reference point.  In a foreign language, the keyword might vary.  You could always use _tk or _tra since the underscore translates english into the localized language form.
If this doesn't answer your question, you will need to be a lot more descriptive of what you want.
Message 7 of 8
andresep82
in reply to: dbroad
yes¡¡¡¡ work¡¡¡¡ but......when I insert the point I have to put the command manually, there is some way of putting it automatic?
(command "_tk")
 How join in one?
thanks¡¡¡¡
Message 8 of 8
dbroad
If that is what you want, I'm not sure it can be done.  The (command "_tra") will not be sent until a response from the user.  Conventional tracking depends on user entry.  You could simulate tracking by creating a getpoint loop that would end with the enter, such as
;;set orthomode on
(setq pt (getpoint "\nSelect point: "))
(while (setq ptn (getpoint pt "\nSelect next tracking point or enter to continue: "))
  (setq pt ptn)
 ;;possible turn orthomode back on but there is no way to lock it on without a sysvar reactor.
;;pt is final tracking point at this point
”Boost
