Visual LISP, AutoLISP and General Customization
get bounding box of entities on layer & use for ssget with filter
16 REPLIES 16
Message 1 of 17
mid-awe
1738 Views, 16 Replies
Hi all,
I am attempting to make a selection-set of all entities within the bounding box of all entities on a specific layer.
I know that sounds confusing so I'll try to explain. I need to get the bounding box of my border & use it with ssget to select all blocks while ignoring all blocks outside of my border.
I have having trouble feeding the bounding box points to the ssget function. What am I doing wrong?
(AND (SETQ BLST	(LIST "BUZZTOP"	"CANISTER1" "FUSECANISTER2" "MDXR3" "NOZZLE" "P3" "PP" "StepNozzle" "VENTURISKIMMER2")
	   SS	(SSADD)
	   S	(SSGET "x" '((8 . "BORDER")))
     (VLA-GETBOUNDINGBOX (VLAX-ENAME->VLA-OBJECT (SSNAME S 0)) 'LL 'UR)
     (SETQ LL  (VLAX-SAFEARRAY->LIST LL)
	   UR  (VLAX-SAFEARRAY->LIST UR)
	   SS1 (SSGET "B" 'LL 'UR (LIST '(0 . "insert") (CONS 2 (STRCAT "`*U*" BLST)) '(410 . "Model")))
 Thanks in advance for any help.
16 REPLIES 16
Message 2 of 17
hmsilva
in reply to: mid-awe
Hi mid-awe,
perhaps something like this
(AND (SETQ BLST	 ",BUZZTOP,CANISTER1,FUSECANISTER2,MDXR3,NOZZLE,P3,PP,StepNozzle,VENTURISKIMMER2l"
	   SS	(SSADD)
	   S	(SSGET "x" '((8 . "BORDER") (410 . "Model")))
		   SS1 (SSGET "w" LL UR (LIST '(0 . "insert") (CONS 2 (STRCAT "`*U*" BLST)) '(410 . "Model")))
Henrique
Message 3 of 17
mid-awe
in reply to: hmsilva
Unfortunately that didn't work. I had thought it just might since I really don't know if the "B" box selection option still exists in AC2014 (I'm using).
My border is made of a single closed lwpolyline, if that makes any difference. The only other thing that I can think of is that my bounding box points return as:
((-1.0e-008 -1.00001e-008 -1.0e-008) (1584.0 996.0 1.0e-008))
It's unrecognizable to me, maybe someone can determine the issue. Is that point list good? I'm not sure what I'm looking at there.
Message 4 of 17
hmsilva
Should work, I did change the "B" mode to "W"...
Try this one
(AND (SETQ BLST	 ",BUZZTOP,CANISTER1,FUSECANISTER2,MDXR3,NOZZLE,P3,PP,StepNozzle,VENTURISKIMMER2"
	   SS	(SSADD)
	   UR  (VLAX-SAFEARRAY->LIST UR))
     (vl-cmdf "_.zoom" "_W" LL UR)
     (setq SS1 (SSGET "_W" LL UR (LIST '(0 . "insert") (CONS 2 (STRCAT "`*U*" BLST)) '(410 . "Model"))))
     (vl-cmdf "_.zoom" "_P")
Henrique
Message 5 of 17
Lee_Mac
Hi mid-awe,
The following is untested, but may help:
(defun c:test ( / app bor llp lst sel str urp )
    (setq lst '("BUZZTOP" "CANISTER1" "FUSECANISTER2" "MDXR3" "NOZZLE" "P3" "PP" "StepNozzle" "VENTURISKIMMER2")
          str  (apply 'strcat (mapcar '(lambda ( x ) (strcat "," x)) lst))
          app  (vlax-get-acad-object)
    (if (setq bor (ssget "_X" '((8 . "BORDER") (410 . "Model"))))
        (progn
            (vla-getboundingbox (vlax-ename->vla-object (ssname bor 0)) 'llp 'urp)
            (vla-zoomwindow app llp urp)
            (if (setq sel
                    (ssget "_C"
                        (trans (vlax-safearray->list urp) 0 1)
                        (trans (vlax-safearray->list llp) 0 1)
                        (list
                           '(0 . "INSERT")
                            (cons 2 (strcat "`*U*" str))
                           '(410 . "Model")
                (sssetfirst nil sel)
                (princ "\nNo objects found within border.")
            (vla-zoomprevious app)
        (princ "\nBorder not found in Modelspace.")
    (princ)
(vl-load-com) (princ)
Message 6 of 17
mid-awe
in reply to: Lee_Mac
Thank you Lee,
That did it. Please, help me understand why yours works and Henrique and I got nil. (that's not fair of me 😉 Henrique tried to fix my mess.)
As I work your sample into my main program, I found that I did not work without the:
 part. It seems that just makes sure that the border is entirely visible before selecting it. I still don't understand it because I was zoomed out a little more than necessary when running the junky version. Also,
(TRANS (VLAX-SAFEARRAY->LIST URP) 0 1)
 Shouldn't make a difference, unless I'm not in WCS? Right?
Message 7 of 17
mid-awe
Henrique, Thank you, but it still comes up nil. Lee's sample works, now I hope he has time to shed some light on it for me.
Thanks again.
Message 8 of 17
Kent1Cooper
@mid-awe wrote:
... bounding box points return as:
Parts of that are in scientific notation.  The e stands for exponent, applied to 10.  So 1.0e-008 means 1 times 10 to the minus-8 power, which is pretty darned close to zero.  You sometimes get that kind of result with calculated points.  It shouldn't affect the working of the routine, unless you have some things mighty close to the edge of the border, so that parts of them fall within that tiny tolerance of difference between the bounding box window and the actual outline, which doesn't seem likely in any actual drawing situation.
Kent Cooper, AIA
Message 9 of 17
mid-awe
Thank you Kent.
They are in 3D points so I expected 0.0 one for each list. That is what fooled me. For a 2D drawing it made no sense.
Message 10 of 17
hmsilva
Hi mid-awe,
I did add a zoom window to ensure the blocks visibility before performing the selection window, so it should select all blocks inside the border...
Henrique
Message 11 of 17
mid-awe
That is strange, when tested it only returned nil. I can't say why.
I did nothing beyond plugging Lee's code and it worked.
Thank you for your help Henrique, I am grateful. Your suggestions usually work immediately.
Message 12 of 17
hmsilva
mid-awe,
it will be possible for you to attach a sample dwg with the border and a few DynaBlocks, just for testing?
Henrique
Message 13 of 17
mid-awe
I tried this again. Apparently, I didn't copy it exactly. I must've been in a hurry and only amended my code with the differences and missed the:
part. My apologies. This version works.
Thank you Henrique.
Message 14 of 17
hmsilva
You're welcome, mid-awe
Glad it worked
Henrique
Message 15 of 17
Lee_Mac
mid-awe wrote:
Thank you Lee,
As you've probably gathered, the graphical selection methods will only select objects visible on screen - this even applies to block components, as the following animation demonstrates:
I have noted this subtle behaviour in my ssget function reference, where applicable.
mid-awe wrote:
Also,
Correct - ssget accepts UCS points, the getboundingbox method returns points in WCS.
Message 16 of 17
mid-awe
Thank you again Lee. Sir, you are a gentleman and a scholar.
Message 17 of 17
Lee_Mac
You're most welcome mid-awe. Smiley Happy
”Boost
