Visual LISP, AutoLISP and General Customization
feature and polyline flow direction (another one)
1 REPLY 1
d1of2
696 Views, 1 Reply
I have a linetype
*DIVERSION_LARGE,diversion large ---- >> ---- >> ---- >> ----
A,.5,-.2,["<<",standard,S=.15,r=0,U=0.0,X=-0.1,Y=-.05],-.2
when I draw a polyline, or use it as the linetype in a feature line style, the arrows seem to revrse whenever there is a change in direction any significance. Also, the reverse command and reversefeature command have no effect. Rotating a segment does not change the direction. I know I must be missing something.
in the attached, I have a feature line, and a polyline that the arrows change direction when the feature does.
thank you in advance for your help
Windows 7 64
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
1 REPLY 1
dbroad
in reply to: d1of2
Try removing the U specification from the linetype and enable linetype generation in the polyline.  To enable it globally for polylines yet to be drawn, use plinegen.  I would also reverse your linetype to be consistent to its description.
A,.5,-.2,[">>",standard,S=.15,r=0,X=-0.1,Y=-.05],-.2
Architect, Registered NC, VA, SC, & GA.
”Boost
