Visual LISP, AutoLISP and General Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
event handler
- Highlight
- Email to a Friend
Is it possible to write an event handler for an autocad event/ command like insert new block ? I want the event to trigger the execution of an update routine . something like this post
http://forums.autodesk.com/t5/Visual-Basic-Customi
how do I access the autocad object in autolisp?
Insia
Re: event handler
- Highlight
- Email to a Friend
Insia,
that's depand on what you are planning to do when insert command is fired?
can you clarify?
Moshe
Re: event handler
- Highlight
- Email to a Friend
I have a DCL window where I let the modeller specify a value type for each attribute of each block in the drawing and I store it in a nested association list . The association list is as follows
((blockName1 attributeAssociationList1) (blockName2 attributeAssociationList2)
where attributeAssnList is another association list like
((attributeTagName1 attributeValueType1) ((attributeTagName2 attributeValueType2)
I have an updateAssociationList function which updates this data structure by comparing it against the state of the current drawing.
I was hoping to call this function when a block/attribute is inserted /deleted /edited.
Thank you ,
Insia
Re: event handler
- Highlight
- Email to a Friend
if i understand you right? you have some blocks attribute data list that store where? in an external file?
and you got some dwg files that you want to update their attributes value?
i do not think that this should be done with Reactors, all you need is to run your update routine on the blocks
to update their attributes and attributes values as a batch and that it?
Moshe
Re: event handler
- Highlight
- Email to a Friend
I wasn't aware of the concept of reactors..seems to me that is what I was looking for. I think I agree with you though, It might not be worth the overhead. I have to look into reactors a bit more.thank you for pointing me in the right direction.
