Visual LISP, AutoLISP and General Customization
Valued Mentor
Rich.O.3d
Message 1 of 5 (469 Views)
edit attribute text in multiple drawings
469 Views, 4 Replies
09-16-2012 03:51 PM
hi,
I need to be able to batch process a bunch of title block attributes automatically.
Block Name: Title Block
Tag Name: SH
Currently they come out with just the number 1, 2 , 3 etc I need to add a leading zero ie 01, 02, 03 etc
All the scripts I have will just replace the number with another
I just want to append the zero infront of the existing number
ie the code will need to read the existing number and decide if its less than 10. if it is less than 10, then the code just needs to append the leading 0. if its 10 or over, then do nothing.
can anyone achieve this please
Cheers
Rich.O
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
*Expert Elite*
pbejse
Message 2 of 5 (459 Views)
Re: edit attribute text in multiple drawings
09-16-2012 05:26 PM in reply to: Rich.O.3d
Tag Name: SH
(defun PrefAtt (bn tag)
  (vlax-for layout (vla-get-layouts
		     (vla-get-activedocument (vlax-get-acad-object))
    (vlax-for itm (vla-get-block layout)
      (if (and
	    (= (vla-get-objectname itm) "AcDbBlockReference")
	    (= (strcase (vla-get-name itm)) (strcase bn))
	    (= (vla-get-HasAttributes itm) :vlax-true)
	(foreach tagV (vlax-invoke itm 'GetAttributes)
	  (if (and (eq (vla-get-tagstring tagV) (strcase tag))
		   (< 0 (read (setq str (vla-get-textstring tagV))) 10)
	    (vla-put-textstring tagV (strcat "0" str))
  )(princ)
(prefatt "Title Block" "SH")
You can run this with script or modify the code for ODBX use:
HTH
Distinguished Mentor
_Tharwat
Message 3 of 5 (429 Views)
09-17-2012 01:10 AM in reply to: Rich.O.3d
Notings different than pBe 's codes , except it would unlock all layers before sercheaing for specific attributed blocks
and unlocked them back after making the changes if the certeria matched of course .
(defun c:TesT (/ Unlock-layers lock-layers l lst ss n e i)
  ;; 		 Tharwat 17. Sep. 2012   			;
  ;; add to the attributed values in Blocks that		;
  ;; are less than 10 to (01, 02, 03, 04, 05, 06, 07, 08, 09,)	;
  (while (setq l (tblnext "LAYER" (null l)))
    (if (eq (Logand 4 (cdr (assoc 70 l))) 4)
      (setq lst (cons (cdr (assoc 2 l)) lst))
  (defun Unlock-layers (layerlist / tbl)
    (foreach x layerlist
      (if (tblsearch "LAYER" x)
        (entmod (subst (cons 70 0) (assoc 70 (setq tbl (entget (tblobjname "LAYER" x)))) tbl))
    (command "_.regen")
  (defun lock-layers (layerlist / tbl)
        (entmod (subst (cons 70 4) (assoc 70 (setq tbl (entget (tblobjname "LAYER" x)))) tbl))
    (command "_.regen")
  (if lst
    (Unlock-layers lst)
  (if (setq ss (ssget "_x" '((0 . "INSERT") (66 . 1) (2 . "Title Block"))))
    (repeat (setq i (sslength ss))
      (setq n (entnext (ssname ss (setq i (1- i)))))
      (while (not (eq (cdr (assoc 0 (setq e (entget n)))) "SEQEND"))
        (if (and (eq (cdr (assoc 2 e)) "SH") (numberp (atoi (cdr (assoc 1 e)))) (< (atoi (cdr (assoc 1 e))) 10))
          (entmod (subst (cons 1 (strcat "0" (cdr (assoc 1 e)))) (assoc 1 e) e))
        (setq n (entnext n))
      (setq n nil)
    (princ)
  (if lst
    (lock-layers lst)
  (princ)
 Tharwat
____________________________________________________
Get learn and learn and practice , to become experienced guy .
*Expert Elite*
pbejse
Message 4 of 5 (395 Views)
09-17-2012 05:58 PM in reply to: _Tharwat
Updated code [to remove white spaces]
(defun PrefAtt (bn tag)(vl-load-com)
      (if (and
		   (< 0 (setq str (read (vla-get-textstring tagV))) 10)
	    (vl-catch-all-error-p
	      (vl-catch-all-apply  'vla-put-textstring (list tagV (strcat "0" (Itoa str)))))
  )(princ)
HTH
Valued Mentor
Rich.O.3d
Message 5 of 5 (376 Views)
09-18-2012 06:54 PM in reply to: pbejse
thanks guys
I will try out as soon as I get a chance (under pump atm for project deliverables)
CAD Management 101:
You are not logged in.
Announcements
Need installation help?
Ask the Community
