Kent:
Are you aware that you can Fillet;Radius,0 two parallel lines? The command apparently computes the radius as being half the distance between the two lines.
This may be useful to someone:
(defun c:TTA ( / e ent1 ent2 p p1 p2 ip @delta @tan delta tan rad ba ea)
(vl-load-com) ;; TangentTangentArc (03-21-18) by John Uhden ;;----------------------------------------------------------- ;; This function returns the tangent of an angle in radians: (defun @tan (ang)(/ (sin ang)(cos ang))) ;;----------------------------------------------------------------------- ;; This function returns the deflection angle (in radians) of two angles: (defun @delta (a1 a2) (cond ((> a1 (+ a2 pi)) (- (+ a2 pi pi) a1) ) ((> a2 (+ a1 pi)) (- a2 (+ a1 pi pi)) ) (1 (- a2 a1)) ) ) (and (setq e (entsel "\nSelect first line at desired point of tangency: ")) (setq ent1 (entget (car e)) p (vlax-curve-getclosestpointto (car e) (cadr e))) (setq e (entsel "\nSelect 2nd line in vicinity of where you think 2nd tangent is: ")) (setq ent2 (entget (car e)) p2 (vlax-curve-getclosestpointto (car e) (cadr e))) (setq p1 (cdr (assoc 10 ent2))) (or (setq ip (inters (cdr (assoc 10 ent1)) p p1 p2 nil)) (alert "Lines do not intersect.") ) (setq tan (distance p ip)) (setq delta (@delta (angle p ip)(angle ip p2))) ;; T=R*tan(delta/2) ;; R=T/tan(delta/2) (setq rad (/ tan (@tan (abs (/ delta 2))))) (if (minusp delta) (setq rp (polar p (- (angle p ip)(* 0.5 pi)) rad) ba (+ (angle ip p2)(* 0.5 pi)) ea (angle rp p) ) (setq rp (polar p (+ (angle p ip)(* 0.5 pi)) rad) ba (angle rp p) ea (+ ba delta) ) ) (entmake (list '(0 . "ARC")(cons 10 rp)(cons 40 rad)(cons 50 ba)(cons 51 ea))) ) (princ) )
Of course it is currently lacking any error or undo controls.
John F. Uhden
Certainly, and not just with 0 radius. You can do Fillet / Radius / anything-whatever, and if the two Lines are parallel, the result will be the same. But it always puts one end of the Arc at the nearer endpoint of the first Line selected -- even in No-Trim mode, it won't put it at a somewhere-along-the-way selected location as routines here will.
I didn't know about "anything-whatever." Thanks for that.
Now that I think about it, my routine could be embellished to handle parallel lines, if anyone is interested.
It should also report the curve data.
John F. Uhden
Okay.
This one handles parallel lines, has error and undo controls, and reports the curve data...
(defun c:TTA ( / *error* e ent1 ent2 p p1 p2 ip @delta @tan delta tan rad ba ea) ;; TangentTangentArc (03-21-18) by John Uhden (gc) (vl-load-com) (or *acad* (setq *acad* (vlax-get-acad-object))) (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*))) (defun *error* (error) (if (vl-position cmdecho '(0 1))(setvar "cmdecho" cmdecho)) (vla-endundomark *doc*) (cond ((not error)) ((wcmatch (strcase error) "*QUIT*,*CANCEL*")) (1 (princ (strcat "\nERROR: " error))) ) (princ) ) (vla-endundomark *doc*) (vla-startundomark *doc*) (setq cmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (command "_.expert" (getvar "expert")) ;; dummy command ;;------------------------------------------------------------------------------------------- ;; This function returns the tangent of an angle in radiansa: (defun @tan (ang)(/ (sin ang)(cos ang))) ;;----------------------------------------------------------------------------------------------------------- ;; This function returns the deflection angle (in radians) of two angles: (defun @delta (a1 a2) (cond ((> a1 (+ a2 pi)) (- (+ a2 pi pi) a1) ) ((> a2 (+ a1 pi)) (- a2 (+ a1 pi pi)) ) (1 (- a2 a1)) ) ) (and (setq e (entsel "\nSelect first line at desired point of tangency: ")) (setq ent1 (entget (car e)) p (vlax-curve-getclosestpointto (car e) (cadr e))) (setq e (entsel "\nSelect 2nd line in vicinity of where you think 2nd tangent is: ")) (setq ent2 (entget (car e)) p2 (vlax-curve-getclosestpointto (car e) (cadr e))) (setq p1 (cdr (assoc 10 ent2))) (if (setq ip (inters (cdr (assoc 10 ent1)) p p1 p2 nil)) (progn (setq tan (distance p ip)) (setq delta (@delta (angle p ip)(angle ip p2))) ;; T=R*tan(delta/2) ;; R=T/tan(delta/2) (setq rad (/ tan (@tan (abs (/ delta 2))))) (if (minusp delta) (setq rp (polar p (- (angle p ip)(* 0.5 pi)) rad) ba (+ (angle ip p2)(* 0.5 pi)) ea (angle rp p) ) (setq rp (polar p (+ (angle p ip)(* 0.5 pi)) rad) ba (angle rp p) ea (+ ba delta) ) ) ) ;; NOTE that when lines are parallel, this function always creates ;; the arc CCW from the first pick point, because by definition ;; arcs are always defined in a CCW direction. (setq p3 (polar p (+ (angle p (cdr (assoc 10 ent1))) (* 0.5 pi)) 100) p2 (inters p p3 p1 p2 nil) rad (* 0.5 (distance p p2)) rp (polar p (angle p p2) rad) ba (angle rp p) ea (angle rp p2) delta pi ) ) (or (entmake (list '(0 . "ARC")(cons 10 rp)(cons 40 rad)(cons 50 ba)(cons 51 ea))) (alert "Arc creation failed.") ) (princ (strcat "\nRadius = " (rtos rad (getvar "lunits") 3) "\nDelta = " (angtos delta 1 4) "\nLength = " (rtos (* delta rad)(getvar "lunits") 3) ) ) ) (*error* nil) )
John F. Uhden
@Anonymouswrote:
Is there any way to draw an arc tangent to 2 lines? thanks.
Hello from 9 years in the future. (2018).
I was wanting to do the same thing in AutoCAD 2016, I was fairly sure I had done it before while learning AutoCAD in college, but had forgotten how to do so.
After some searching around I found an article by Auto Desk about working with splines: Draw a spline tangent to and connecting two lines or curves
In AutoCAD 2016 it is as easy as typing in "blend" and selecting both lines.
I hope this helps people like me for many years to come! 🙂
I did not realize people were posting on this thread in 2018! I have replied to the OP's question after finding out about the "blend" command here:
In AutoCAD 2016 connecting two lines or curves that exist in 3D space is as easy as typing "blend" and selecting the two lines/curves in question. (I believe the lines/curves must be open on the end you are attempting to connect.)
I have just tested if blend works in 2 dimension space and it absolutely does.
@Kent1Cooper, I found your lisp routine some time ago and me and my staff use it on a fairly regular basis. As a former MicroStation user, this is a God send. The only item I am hoping you could improve upon is when the second object is an arc or circle, I find the tangent arc being drawn seems to always go to the nearest side rather than near the point of selection that is, most of the time, on the far side of the arc or circle. Please let me know if you need a screenshot of my results. Thanks and good luck if you have time to explore this.
@evietmeier_1207 wrote:
..... Please let me know if you need a screenshot of my results. ....
Yes, please. I am not getting results like that, if I understand correctly what you mean, but maybe I don't.
I was coming from a snap endpoint of two different arcs and tangent to two other arcs. See the screenshot. Thanks
What are you starting with, where are your pick locations, what in the image is the wrong result, and what do you want it to look like? Could part of the problem be ambiguity about multiple objects at a pick location? If so, can you use HIDEOBJECTS to take some of them out of consideration temporarily?
Typically, I get in close enough, or the drawing field is not so cluttered. The screenshot show PT1 Endpoint and PT2 Tangent. The dashed arc is the desired result.
Thanks for taking the time to look at this.
I set up a similar situation, and it did as expected, but there may be something very specific about the geometry. Post a [small] sample drawing file containing a few things in that area that go wrong.
Here's a small sample of what I encounter. I left enough line work for context. Again, the dashed arc is what gets drawn when trying to go from an arc endpoint to a tangent point on a second arc.
Thanks again
It does the same for me. And you have the latest, but since that's almost 13 years old, I'll have to re-familiarize myself with how it does its thing.
In the meantime, since it seems to be peculiar to the two-Arcs situation, you can do this:
Draw a temporary LINE from that endpoint of the first Arc to its CENter. Rotate that Line 90° about that ENDpoint, so the new Line is tangent with the Arc at their shared endpoint. Temporarily MOVE the first Arc out of the way. Run the AT2 command from the ENDpoint of that temporary Line to the second Arc, which [for me] gives the correct resulting new Arc. ERASE the temporary Line and MOVE the first Arc back to where it was. [And in your sample situation, Trim the second Arc a little to the new one.]
The fillet 2 arcs has always been a problem, generally you get a big "S" as the answer, there is non acad Civil software that does it by asking for an approx center of the proposed arc. There is like 4 solutions for add an arc between 2 arcs.
It has been discussed before and most of us just use Circle TTR then trim excess circle.
Just tried adding an arc in my Bricscad V20 between 2 arcs using fillet and guess what it worked, but experience tells me it often doesn't.
@Sea-Haven wrote:
.... most of us just use Circle TTR then trim excess circle. ....
That's fine if you know the radius, and when that is what matters, not the point of tangency. This topic is about specifying the point of tangency on one of the objects, with the radius being a result as needed to end up tangent to the other object.
@Kent1Cooper, That is a nice work-around, and it works. I look forward to your v 1.1 or 2.0 or whatever you'd want to call it if you write a new version. Otherwise, thanks for the suggested work-around.
