I am looking for how to draw a text entity in 3d, where I know the 3d ins point, and the plane it should be flat to.
I have not drawn text or inserted blocks programatically before where the plane they lie on is not flat.
I have done it before by setting a ucs and drawing stuff, but now I want no switches of UCS involved.
So far, I think I must figure out the OCS of the plane I want, but am not sure what to do from there.
I'm looking around so will post what I find.
thx
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
I poked around a bit, and found a good set of posts here:
http://www.theswamp.org/index.php?topic=39162.msg443987#msg443987
What that code lets you do is modify an existing entity to be transformed by a start and end normal vector.
That is definate progress, as it can all be done programatically, no UCS flat to desired normal direction necessary.
vla-transformby is the key function, you just have to know how to construct the matricies, which would take me months on my own.
I get what they are, but just have not reviewed the math in a long time.
So this is good, but I would prefer to make an entity correctly transformed, using entmake.
I have a feeling its just setting the 210 group to the OCS matrix (code on the thread liked to), and finding the correct 10 and 11 groups for the OCS.
I bet its right in front of me, but I am not sure how to translate a point in WCS to the OCS, probably just a trans function call...
What would the 11 group be though?
On text flat to WCS, it is always (0 0 0), I need to read on that group.
I see, 11 group is 0 0 0 even for text not normal to WCS, IF it is justified as left/baseline.
So whatever trans I do for 10 group, I must do for 11 group most likely.
