Visual LISP, AutoLISP and General Customization
copy layers'name (NOT GEOMETRIES) from multiple .dwg to ONE .dwg
6 REPLIES 6
sabysaby
1055 Views, 6 Replies
Hi all!
I need to create ONE dwg (called "structure.dwg") containing ALL, AND ONLY!, the layers'names (NOT THEIR GEOMETRIES!) coming from other 1000 dwg.
Does exist a lisp rountine that can automate that?
Thanks in advance!
Saby
Tags (3)
6 REPLIES 6
Lee_Mac
in reply to: sabysaby
You could automate my Steal program to perform this task.
sabysaby
in reply to: Lee_Mac
WOW!
It's great!
Thanks very much for now, but....I've got another little question:
How can I select more than one dwg to import their layers once in the same time?
The "select drawing to steal from" window doesn't allow me to make a mutiple dwg selection......
Have I to use "STEALALL" one dwg by one?
Instead, using STEALTEMPLATES, I can select multiple .dwt files.
Is there an alternative methods of saving all my dwg in a dwt format?
Thanks in advance for everything!!
Saby
Lee_Mac
Hi Saby,
Thank you, I'm glad you like the program Smiley Happy
For multiple drawings, load my Steal program and also load this program, and then run the following code:
(defun c:stealdwgs nil
    (foreach dwg (LM:getfiles "Select Drawings to Steal from" nil "dwg")
        (Steal dwg
                ;; Items to Steal:
                ;("Blocks"                  ("*"))
                 ("Layers"                  ("*"))
                ;("Linetypes"               ("*"))
                ;("Text Styles"             ("*"))
                ;("Dimension Styles"        ("*"))
                ;("Layouts"                 ("*"))
                ;("Views"                   ("*"))
                ;("Materials"               ("*"))
                ;("Viewports"               ("*"))
                ;("Page Setups"             ("*"))
                ;("User Coordinate Systems" ("*"))
                ;("Groups"                  ("*"))
                ;("Drawing Properties"      ("*"))
                ;("Custom Properties"       ("*"))
                ;("Multileader Styles"      ("*"))
                ;("Multiline Styles"        ("*"))
                ;("Table Styles"            ("*"))
                ;("Scales"                  ("*"))
                ;("Layer States"            ("*"))
    (princ)
The above is currently set to import only LAYERS - you can uncomment (remove the semi-colon) to control which collections are imported.
Lee
sabysaby
WOW!!Great!!!!
You are a genius!!
You made my day!!
You solved me a great problem, that's why I've just made you a donation to thank you!!
Saby
ps
I'm going to post a new "little" problem called "check elevation/Z geometries errors"... maybe you could help me again!
Lee_Mac
That's incredibly kind of you Saby, thank you very much indeed Smiley Happy
I have downloaded the Steal file but it only copied the layer name. I need to copy the content of the layer.
Also I need copy the layers from 3600 .dwg to a single dwg.
Please can you assist with this?
”Boost
