Visual LISP, AutoLISP and General Customization
convert polyline - Bad SSGET list
3 REPLIES 3
Nik-D
702 Views, 3 Replies
Hi all
I'm new to lisp so this may seem like a silly question but i just cannot seem to get this thing to work.
I have a data structure called LayerList in the format [LIST "LayerName" "Linetype" Thickness Color]
I then use the following piece of code to go through the structure selecting polylines and converting all polylines on a given layer to the correct thickness
   (foreach layr layerlist
       (setq player (car layr))
              (if (setq ss (ssget "x" '((0 . "*polyLINE") (8 . player ) )))
                      (command "pedit" "m" ss "" "w" 0.15 "")
                      (princ "\nNo polylines exist!")
However all i keep getting is Bad SSGET list value at the command line,
What am i doing wrong??
Nik
3 REPLIES 3
Nik-D
in reply to: Nik-D
Solved it, I changed the code as follows
    (if (setq ss (ssget "_x" (list'(0 . "*POLYLINE") (cons 8  (car layr)) )  ))
    (princ)
Kent1Cooper
in reply to: Nik-D
Good for you for figuring it out.  I would, however, suggest that you stick with the word Width [as in the name of the option used in your Pedit command] rather than referring to an object's Thickness.  Polylines [and many other entity types] can also have Thickness, which has a specific [and different from Width] definition in AutoCAD: their dimension in the up-off-the-page Z direction.
Kent Cooper, AIA
Nik-D
in reply to: Kent1Cooper
Will do. Thanks Kent
”Boost
