I assume you'd have to step through the Polyline vertices, check the distance between each adjacent
pair to calculate the elevation change along the segment between them, and build the 3DPolyline from
the calculated set of points. (Not that I can tell you how to do that, exactly, without figuring a
bunch of stuff out, but....) You could erase the original Pline, or not. [If the Pline has any
*arc* segments, you wouldn't be able to do it -- 3DPolylines can't have those.]
Kent Cooper
wrote...
is it possible or does anyone have a routine that will convert a polyline to a 3d poly? i have a
trail system and i know my start elevation. i want to grade it at 5%.
1. prompt to select pline
2. pick start point and give elevation
3. prompt "do want to grade at slope or give ending elevation?
4. based on no. 3 response convert polyline into a 3d poly.
