code in distances as stations
7 REPLIES 7
Message 1 of 8
FSJ_Mo
647 Views, 7 Replies
I have a lisp program that uses a 3dpoly to draw a profile of existing ground elevations. Currently, the program only writes in distances as whole numbers (ie:500 or 1600) I would like it to write them as stations along the profile (ie: 0+500  or 1+600) does anyone have a peice of code for doing this?
I run civil3d2012, but most of the rest of the office uses map3d2012
map3d2012 and civil3d2012
7 REPLIES 7
Message 2 of 8
_Tharwat
in reply to: FSJ_Mo
You can use the function strcat to add any string you want ,
e.g. (strcat "0+" "500)
Message 3 of 8
rkmcswain
in reply to: FSJ_Mo
Message 4 of 8
Kent1Cooper
in reply to: FSJ_Mo
@FSJ_Mo wrote:
I have a lisp program that uses a 3dpoly to draw a profile of existing ground elevations. Currently, the program only writes in distances as whole numbers (ie:500 or 1600) I would like it to write them as stations along the profile (ie: 0+500  or 1+600) ....
If the program already derives text strings representing integer values, and it's just a matter of converting them to stationing format, try incorporating something like this:
(defun station (num)
  (while (< (strlen num) 4)
    (setq num (strcat "0" num))
  ); while
  (strcat
    (substr num 1 (- (strlen num) 3))
    (substr num (- (strlen num) 2))
  ); strcat
); defun
Usage:
Command: (station "500")
"0+500"
Command: (station "1600")
"1+600"
Command: (station "45")
"0+045"
Command: (station "123456")
"123+456"
Command: (station "1")
"0+001"
[You would presumably feed in a variable containing the text string, set as the result of what the other program works out, rather than text strings explicitly.]
If you ever need to go beyond six digits, that could be accomplished, but it would require adjustments.
Kent Cooper, AIA
Message 5 of 8
Kent1Cooper
in reply to: Kent1Cooper
That is, if numbers beyond six digits need additional plus signs in them, such as 1+234+567 [I don't know how these things work, being a mere Architect -- I'm just manipulating text here].  If such a value would ever be encountered but still needs only the one plus sign to separate the last three digits, then the routine works as posted:
Command: (station "1234567")
"1234+567"
Kent Cooper, AIA
Message 6 of 8
FSJ_Mo
thanks for all the help guys!
Message 7 of 8
Kent1Cooper
in reply to: FSJ_Mo
You're welcome.  Just for my own curiosity, do stationing numbers ever get to be 7 digits or more, and if so, would they need to have additional + signs separating groups of 3, like commas separating units from thousands from millions?  I'd like to have a little more inkling of how they're used, since questions involving them come up here now and then.
Kent Cooper, AIA
Message 8 of 8
FSJ_Mo
We are a survey company servicing mostly the oil & gas industry in NE British Columbia and our projects are usually under 20Km long so we would have no need. A project would have to be over 1000Kms long before this would apply and typically a project of this length would be broken into smaller segments. IMO
”Boost
