I kind of thought it would require a reactor, (something I'm entirely new
too!) I was thinking that this program I was thinking of could react after
the fact, and just change the color based upon it's relation to a similar
layer. sort of run through the layer list find the *xstg layers check em
against the similar layers and then change the color, maybe it can react to
any new layer that's created... I'll also look for Eric's and Matt's
program... Thanks Nauman...
randy
"Nauman M" wrote in message
news:3AF84F48.58C0FF5@email.com...
> you can have a reactor set to trap AecGenerateLayerKey, when the command
> ends you can see what layer it created, and if a layer generated by it,
> you parse through and if its override is demo, change the layer table
> color to 8 for that layer.
> now I am assuming that WALLADD is using AECGENERATELAYER, if they are
> using something other than that, or arx, then I am not sure how you
> would trap. you can also trap the walladd command rather and after it
> finishes you check your layer table, , now this may slow you down.
> so you can react to walladd, and check if overrides are on, then parse
> the table, if not then just exit.
> actually come to think of it, don't react on AECgenerate... as many othe
> commands may use it, and you sure
> dont want your notes to be color 8 and hidden...
> as for reactors, I have the faintest of ideas how to accomplish, but you
> may want to look at Eric's AutoLay program and learn from that and other
> topics here as well.
> It is in lisp and it can be done...what you are looking for, just needs
> creative programming...
> as for checking overrides, and whether they are on, you got to weed
> through the registry, for which I have something, but its buggy and was
> modified by me to figure out overrides, and I dont understand dict
> operations a whole lot. as for the layer table mod, look up in Cust NG
> routines posted by MATT Dillon, and there is a routine in there that
> modifies the layer table. or you can simply accomplish it with the layer
> command , as I heard there are restrictions to using entmod comannds in
> reactors...
> just some ideas....
> Randy Rush wrote:
> > I may be over thinking this thing but let me try and break it down more
and
> > see if my thinking is clear. I want to create these layers with the
color I
> > want without creating the layers manually or setting them up in a
template.
> > When I use overrides it create a new layer based on the layerkey for the
> > entity I'm trying to create. So if I'm drawing walls for example, and
it's
> > color is 4, and I turn on the override to create existing walls, my new
> > layer will be A-Wall-Exst with the same color 4. What I would like to
do is
> > this. use the layerkey override which will create my new layer and have
the
> > color correspond to the list I've created. So when the A-Wall-Exst
layer
> > is created it checks the layerkey color (in this example its 4), then
based
> > on my requirements below changes the color to 135, the corresponding
color
> > for 4. Otherwise I'd have to create duplicate layers of all the entity
> > types that could possibly be existing, a-wall-exst, a-glz-exst,
a-door-exst,
> > etc. etc. Same things goes for demo. I want all demo'd entities to
have
> > the color of 8 and dashed linetype.
> > Randy Rush
> > "R. Robert Bell" wrote in message
> > news:647B069D33707623661DA787DC8BC2DA@in.WebX.maYIadrTaRb...
> > > Randy,
> > > What's the difference between setting up these layers in your
template,
> > and
> > > selecting the desired one, versus selecting a "layerkey" and having a
> > > program set the layer? Am I missing something here?
> > > BTW, it *can* be done in AutoLISP.
> > > http://www.acadx.com
> > > "Randy Rush" wrote in message
> > > news:485CC427176B4634E273066E972664BB@in.WebX.maYIadrTaRb...
> > > | Posted this in desktop customization, but it should probably go
here...
> > > | Here's a special problem. I want to change the color when I turn on
a
> > > layer
> > > | key. For example, I'm drawing walls, I then want to turn on the
"exst"
> > > | layerkey, but I want to use another color in order to differentiate
the
> > > | differences between existing and new. The colors would be:
> > > | New Exst'g
> > > | 1 red 15 dark red
> > > | 2 yellow 55 dark yellow
> > > | 3 green 95 dark green
> > > | 4 cyan 135 dark cyan
> > > | 5 blue 175 dark blue
> > > | 6 magenta 215 dark magenta
> > > | Some how I don't think I can do this in Lisp, it looks like it may
have
> > to
> > > | be done in VB, but I'm very new to VB... any thoughts or ideas?
> > > | Randy Rush
> Nauman M
> CAD Bazaar
> Need to easily Navigate to your Custom Content Folders?
> Need Autolayering for Dimensions without going through Design Center?
> Download the updated ADT Tools for ADT 2 & 3 at
> http://www.cadbazaar.com
