I need to change the value of attributes across multiple papaerspaces as well as the model space. the only code I know to change attributes (that I understand) is as folows hoevere this code seems to nly change the attributes of the current active window (regardless wether paperspace or model space)
(command "-attedit" "y" "BLOCK_NAME" "TAG_NAME" "" "-999999,-999999" "999999,999999" "" "v" "r" "TAG_VALUE" "")
My first option is Autocad FIND command.
If you use FIND command make sure the this box is ticked
And the second option is :
I use this tip from cadalyst to edit the value of attributes in multiple layouts.
This tip will use the ATTIN and ATTOUT commands from Express tools
