Visual LISP, AutoLISP and General Customization
change an attribute text
6 REPLIES 6
richie_hodgson
462 Views, 6 Replies
This has probably been done over and over but I am not undersatanding. I have a block "MANAGER" with Two Attributes "CETOP" and "CEBOT" I would like a lisp to replace what ever is in those attributes with defined text, for my purposes "Text1" and "Text2". I would like a simple routine that even I can understand so I can apply it to a couple of other lisp projects I have.
Richie
6 REPLIES 6
pbejse
in reply to: richie_hodgson
The Vanilla code posted on your other thread is a s simple as it can be richie.
If you want a generic code:
(defun Revall  (dat_ bn / att# sset e an ad )
      (if  (setq sset (ssget "_X" (list '(0 . "INSERT")'(66 . 1) (cons 2 bn))))
            (progn
                  (prompt "\nupdating.......please wait. ")
                  (while (setq e (ssname sset 0))
                        (setq an (entnext e)
                              ad (entget an))
                        (while (= "ATTRIB" (cdr (assoc 0 ad)))
                              (if (setq val (assoc (cdr (assoc 2  ad)) dat_))
                                    (setq ad (entmod (subst (cons 1 (cadr val))
                                                    (assoc 1 ad)
                                                    ad)))
                              (setq an (entnext an)
                                    ad (entget an))
                        (ssdel e sset)
      (princ)
(defun c:CTV  (/ bn tag val data)       ;Chagne TagString value
      (setq bn  "MANAGER"
            tag '("CETOP" "CEBOT"))
      (foreach
             tg  tag
            (setq val  (getstring  t
                             (strcat
                                   "\nEnter New String Value for TAG " tg
            (setq data (cons (list tg val) data)))
      (if data
            (Revall data bn)
You can create as many command name as you please and change the TAG and BN  for specific block
(defun c:CTV2  (/ bn tag val data)
       (setq bn  "AnotherBlockName"
            tag '("TAG1" "TAG2 "TAG3"))
HTH
Hi, many thanks for that, what I am trying to do is put 2 lines of "pre-set" text in those attributes, (setq txt1 "Line1 text") (setq txt2 "Line 2 Text"), so txt1 goes into CETOP and txt2 goes into CEBOT I can see how your code works but not sure how to do this bit with the way you have coded it.
Richie
pbejse
(defun c:reman  nil
 (Revall '(("CETOP" "Line1 text")("CEBOT" "Line 2 text"))  "MANAGER")
That has made me very happy, will try it out tomorrow when I get some time, Gives me two good methos to approach attribute manipulation
Richie
Many thanks, it all works beautifully, have made a couple of changes to suit.
Richie
pbejse
You're welcome. Smiley Happy
Cheers
”Boost
