If everything in the source drawing is colored BYLAYER, than it could be as simple as:
(command "_.Layer" "_C" "whatevercolor" "xrefname|*" "")
(setvar 'visretain 1)
or in macro format:
^C^C-Layer C whatevercolor xrefname|* ;visretain 1
or in script format:
^C^C-Layer
C
whatevercolor
xrefname|*
visretain
1
You could put it on a toolbar or tool pallette button, or a pull-down menu, or a screen menu, or a
tablet menu, or a script, or define it as a command with (defun) and type the command name, or put
that command name in a location in any of the menu types. Exactly how you put it in them varies a
little with the menu type, but if you get into the menu file, you can see how other things are put
there.
Kent Cooper
wrote...
Hello Kent,
Ok.
How does the routine look like? and is it possible to make a
customized button for that?
Serge
