Visual LISP, AutoLISP and General Customization
cant read plot settings from variable in txt file
5 REPLIES 5
The_Caddie
385 Views, 5 Replies
I’m trying to create a plot command that reads settings in from a variable stored in a text file but its becoming muddled up somewhere.
(defun c:MYPLOT ()
;Setting nessesary variables...
				(setq fname "C:/ICT/AutoCAD_Architecture_Suite_2012/CUSTOM/TREADSTONE/PEN/MYOUTPUTDEVICE.PEN")
				(if(setq f(open fname "r"))
				(while (setq MYOUTPUTDEVICE (read-line f))
				(close)))
				(setq fname "C:/ICT/AutoCAD_Architecture_Suite_2012/CUSTOM/TREADSTONE/PEN/MYPAPERSIZE.PEN")
				(while (setq MYPAPERSIZE (read-line f))
				(close)))
				(setq fname "C:/ICT/AutoCAD_Architecture_Suite_2012/CUSTOM/TREADSTONE/PEN/MYPAPERORIENTATION.PEN")
				(while (setq MYPAPERORIENTATION (read-line f))
				(close)))
				(setq fname "C:/ICT/AutoCAD_Architecture_Suite_2012/CUSTOM/TREADSTONE/PEN/MYPAPERPLOTSTYLE.PEN")
				(while (setq MYPAPERPLOTSTYLE (read-line f))
				(close)))
				(setq fname "C:/ICT/AutoCAD_Architecture_Suite_2012/CUSTOM/TREADSTONE/PEN/MYPAPERLINEWEIGHTS.PEN")
				(while (setq MYPAPERLINEWEIGHTS (read-line f))
				(close)))
;this line works...
;(Command "-Plot" "Y" X "\\\\dcmar02\\A03P17A4ZW" "A4 (210 x 297 mm)" "Millimeters" "Landscape" "No" "layout" "1:1" "0.00,0.00" "n" "" "Yes" "No" "Yes" "No" "No" "No" "yes")
;this line dosnt..
(command "-Plot" "Yes" X MYOUTPUTDEVICE MYPAPERSIZE MYPAPERUNITS MYPAPERORIENTATION "no" "Layout" "Fit" "0.00,0.00" "Yes" MYPAPERPLOTSTYLE "No" "No" MYPAPERLINEWEIGHTS "yes" "yes"  "no" "no" "no" "yes")
5 REPLIES 5
Try (close f) instead of (close).
- The debug>Break on Error setting in VLIDE would help in finding these.
After correcting the CLOSE bug you'll notice the program has further problems:
- closing the file inside the loop doesn't make much sense.
- doing a SETQ to the final variable in the test of the WHILE loop isn't useful, as the value after the loop will always be NIL. Use a temporary variable in the test and set the final variable in the loop body:
(if (setq f (open fname "r"))
    (while (setq temp (read-line f))
      (setq MYOUTPUTDEVICE temp)))
(close f)
- Also, make sure you don't have an empty last line in your file: that loop reads every line in the file, saving the last one as value.
yes how stuipid of me BTW I'm custom to ussing ust notepad to write all my lisp, i did however seek the use of Vlide after a while but because of my unfamiliaraty with the Vlide program I was unable to locate the problem
Thankyou for your help
actually I see where the whole problem is occurring its when the plot device is being selected the plot device we have is named \\dcmar02\A03P19 in lisp I tried it as \\\\dcmar02\\A03P19 though that didnt work either
i have a more simple way to demonstrait this lasve the following lisp and you will see exactly wher my problem lies qua the slashes in the MYOUTPUTDEVICE variable.
(defun C:test ()
(setq MYOUTPUTDEVICE (getstring "\\dcmar02\a03p19"))
(alert MYOUTPUTDEVICE )
  how do I manage to include the slashes?
(defun C:test ()
The rule of thumb is: whenever you are using explicit quotation marks, you need to use doubled backslashes - and only then.
GETSTRING  uses PRINC to output its prompt, so your example shows as \dcmar02a03p19,
and reads your answer without quotation, so you don't need to use the Lisp-style doubled backslashes yourself here.
The ALERT call also uses PRINC, so it shows only the actual data, not the escape characters.
”Boost
