i have the following code which works wel for lisp but causes a fatal error for fas, which is beyond me cause I use lisp to load single fas files all the time.
(defun load-lsp () (foreach file (vl-directory-files "C://ICT//AutoCAD_Architecture_suite_2012//FAS//BLOCKS//" "*.FAS" 1) (load (strcat "C:/ICT/AutoCAD_Architecture_suite_2012/FAS/BLOCKS/" file)) ) ) (load-lsp)
thing though it needs to be fas not lisp
(defun load-lsp () (foreach file (vl-directory-files "C://ICT//AutoCAD_Architecture_suite_2012//FAS//BLOCKS//" "*.FAS" 1) (load (strcat "C:/ICT/AutoCAD_Architecture_suite_2012/FAS/BLOCKS/" file)) ) ) (load-lsp)thing though it needs to be fas not lisp
It should work as expected...
Test each .fas separately to see if it gives an error.
Henrique
