Im trying to call forward a specified toolpallet, However If use the following code, the toolpallet dose apear but it also simutainiously drops all other pallets from view, I strictly need the pallet to be brought forward whilst not loosing the sight of all other toolpalette tabs???
(command "*_TOOLPALETTEPATH" "C:/ICT/AutoCAD_Architecture_suite_2012/ATC/FABRIKANT/GEBR_BODEGRAVEN_BV/KOPPELPLATEN.atc")
Solved by rkmcswain. Go to Solution.
doh!
I had forgotten about that command, (also fixed a relating issue thrugh that) thanks 🙂
