@Anonymous wrote:
I am getting an error brkint.lsp successfully loaded.
Command: ; error: malformed list on input
Can you attach the lisp file
Jeff may not still be watching after nine years. The passage of time and changes in website format, etc., may be why it's not working for you, if any of that has affected what happens when you copy and paste the code. But there are various routines out there to do the same kind of thing, such as here.
I looked at that, and the problem may be simply the fact that all line-wrapping is gone, because there are some semicolons commenting out certain things, but the commenting-out applies to more than it should because there are no new lines. I made some assumptions about how much was intended to be commented out in each case, and re-introduced line breaks, resulting in the attached, which works here in very limited testing.
Hi
I have one, but I made it only for polylines. Se in attach
