Visual LISP, AutoLISP and General Customization
bounding box question
6 REPLIES 6
1770 Views, 6 Replies
consider a rectangle rotated 45 degrees
the vla-getbondingbox method, will return the lower left and upper right of
a rectangle's bounding box
how would i obtain the smallest bouding box of the rectangle,
in other words, is there a way to read a 45 rotated ucs for this rectangls.
6 REPLIES 6
As you noted, (vla-getBoundingBox) returns points in WCS coordinates.
Attached is a LISP that returns the bounding box in current UCS
coordinates. You will need to rotate the UCS to match the object to get
the smallest bounding box.
with polar and inters
you can calculate a line from lower left in direction of your text
(attribute...)
a line from upper right with (/ pi 2) change in direction from your
first line
inters the 2 lines and you get the 3. point
do the same with
calculate a line from upper right in direction of the text
a line from lower left with (/ pi 2) change in direction from your first
line
inters and you get the 4. point of your rectangle
Kent1Cooper
What is the rectangle? A Polyline? A Block? If it's a Polyline, and really rectangular, its own vertices are the smallest bounding box, regardless of its rotation angle, so there should be no need for a get-bounding-box operation. If it's a Block, defined [as I have one] as an orthogonal 1-drawing-unit square, with its size determined by scale factors and its angle by its insert rotation, the smallest bounding box could be calculated from those scale and rotation elements of the entity data, or you could rotate the UCS to match its rotation and do Bill's thing.
If you want to find the smallest bounding box of something that's not rectangular, then you would need some way of deciding at what rotation to consider it. Or perhaps you could make a routine that would try it out at a series of different angles, and report back the smallest result, but that would be limited in its precision by the increment between those angles.
Kent Cooper
Mark wrote...
how would i obtain the smallest bouding box of the rectangle....
Kent Cooper, AIA
i am working w/ regions and the rotation is "principal directions"
wrote in message news:6365576@discussion.autodesk.com...
Kent Cooper
Mark wrote...
Kent1Cooper
in reply to: Kent1Cooper
Reviving an old thread, but if someone finds this while looking for a smallest-rectangle-at-any-angle routine, that doesn't require adjusting the UCS as Bill Gilliss's routine above does, and works with any size selection set rather than one object, look at the second version of SmallestRectangle.lsp [the one that's an attachment, not the one in a code window that draws the orthogonal one], here.
Kent Cooper, AIA
mdhutchinson
sometime ago, and under a different employer I purchaced an active  x component that I used in vba. I was also succesful in reading in the library into lisp properties, methods and events. It made matrix math a breaze.
check it out at http://www.bluebit.gr/
I think I did a post on it then on using it in lisp code.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Convex-Hull-optimal-bounding-rectangl...
”Boost
