Visual LISP, AutoLISP and General Customization
autolisp to flip variable
2 REPLIES 2
TexShalter
318 Views, 2 Replies
I'm trying to make an autolisp that "flips" a third party variable. No luck, command line won't recognize after it loads. I've made similar variable flips that work ??
thanks anyone
(defun c:wp (/ wp)
  (setq wp (getvar "kti_archt_wallpoche"))
  (if (= kti_archt_wallpoche 0)(setvar "kti_archt_wallpoche" 1)
  (if (= kti_archt_wallpoche 1)(setvar "kti_archt_wallpoche" 0)
2 REPLIES 2
bgingerich
in reply to: TexShalter
Instead of:
 try:
(setvar "kti_archt_wallpoche" (- 1 (getvar "kti_archt_wallpoche"))
 (if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
Kent1Cooper
thanks anyone
(defun c:wp (/ wp)
I would agree with the other suggestion to just subtract the current value from 1, which spares you the need for the wp variable.  But if you want the double (if) approach, they would need to be:
  (if (= wp 0)(setvar "kti_archt_wallpoche" 1)
  (if (= wp 1)(setvar "kti_archt_wallpoche" 0)
Kent Cooper, AIA
”Boost
