auto change text
3 REPLIES 3
E.S.7.9
323 Views, 3 Replies
auto change text
i wanna change attribute tag which i choice with my specific texts ;
for example , i have text A500 ,B750 ,C1000, D1250, E1500 and i wanna change attribute tags in every click as my specific texts until i found necessary text
is there a lisp somthing like that
3 REPLIES 3
pbejse
in reply to: E.S.7.9
I dont get it E.S.7.9, is that TEXT entity to attribute? or select A500 then select tags to copy string value A500?
E.S.7.9
in reply to: pbejse
those texts are going to be in lisp memory and when i run to lisp command and click to attribute tag , it s going to write there first text "A500" for example if i want to write 3 th text "C1000" i ll click to tag 3 time and lisp will put there to my 3th place text..
of course if there is a possibility
i realised that manually change mean it is a big lost time because there are a lot of attribute blocks i have to change
Lee_Mac
Try the following:
(defun c:attval ( / e l n o p )
    (setq l '("A500" "B750" "C1000" "D1250" "E1500")
          n 0
    (while
        (progn (setvar 'errno 0) (setq e (car (nentsel "\nSelect text or attribute <Exit>: ")))
            (cond
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (= 'ename (type e))
                    (setq o (vlax-ename->vla-object e))
                    (cond
                        (   (not (wcmatch (vla-get-objectname o) "AcDbAttribute,AcDb*Text"))
                            (princ "\nInvalid object selected.")
                        (   (not (vlax-write-enabled-p o))
                            (princ "\nObject is on a locked layer.")
                        (   (equal p o)
                            (vla-put-textstring o (nth (setq n (rem (1+ n) (length l))) l))
                            t
                        (   (setq p o n 0)
                            (vla-put-textstring o (car l))
                            t
    (princ)
(vl-load-com) (princ)
”Boost
