Visual LISP, AutoLISP and General Customization
attributes value into excel
5 REPLIES 5
508 Views, 5 Replies
please help me provide an LISP of puting attributes value of objects in autocad into excel format..
thank you...
5 REPLIES 5
dmfrazier
One option you can try: the Express Tools AttOut command allows you to export attribute info to a text file (tab delimited, I think), which can be opened in Excel and then saved in Excel format (if you wish).
DataExtraction is another one you can try.
in reply to: dmfrazier
thanks..
dmfrazier
Glad to help.
smbrennan
The best part about that - is you can also modify the attributes in bulk within Excel, then import the values back into AutoCAD. We have actually found that to come in handy from time to time.
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
dmfrazier
in reply to: smbrennan
"...import the values back into AutoCAD."
Good point, SM.
OP: This is done (as one might guess) using the ATTIN command.  Be sure not to change the format of the file after editing in Excel.  As stated in Express Tools Help for ATTIN:
"Just make sure that when you save your changes you save them in a tab-delimited ASCII format; otherwise the ATTIN command will not be able to import from the file."
”Boost
