block name
REV_DESC
tags
REVNO1, DATE1, DESC1, CAD1, CHKD1,APVD1
Each attribute has a unique tag, just change the 1 to 2, 3, 4, 5, 6, 7
Want to be able to have a lisp that will be able to fill in the revision data with some preset information and inputed data.
example lisp name/command "REVA" will be for the tags ending in 1
Revno1 = A
Date1 = get current date
Desc1 = inputed by me
Cad1 = DMB
Chkd1 = ROB
Apvd1 = PM
lisp/command "REVB"
Revno2 = B
Date2 = get current date
Desc2 = inputed by me
Cad2 = DMB
Chkd2 = ROB
Apvd2 = PM
Now the fun part I would also like it to change the Revison number in another block at the same time to match the current revison command from above. So if I run REVE the drawing revision in the title block will also update.
that block name is SBC_TITLE
and the tag name is REVNO
thank you.
Please try attached ALTEXT.vlx.
Command: ALTEXT
Select objects: ALL
Select objects: (Enter)
Which attribute to be changed (Enter 0 to search attribute tag name): Attribute No.<1>: 0
Enter search pattern: Revno1
Settings as below:
Press OK to update all attribute with tag name Revno1 to "A".
Repeat above steps, change tag name search pattern and "New text" in the settings dialogue box.
