Visual LISP, AutoLISP and General Customization
asterisks in custom AutoCAD command
9 REPLIES 9
Message 1 of 10
mikegera
789 Views, 9 Replies
I want to write a very simple program that will turn all layers OFF except the current layer, which I *think* would look something like this:
; "LOFF" command (turn all layers OFF except current layer)
(defun c:loff ()
  (command "-la" "OFF" "*" "n")
  (princ)
Yet this does not work.  What am I doing wrong?  Is it something to do with the astericks?
Thanks for any help as always.
9 REPLIES 9
Message 2 of 10
hmsilva
in reply to: mikegera
Try
(command "Layer" "off""*" "" "")
HTH
Henrique
Message 3 of 10
mikegera
Thanks, but that does not work either.
I am in 2014, FYI, if that matters.
Message 4 of 10
hmsilva
Works for me, AC2010/2012/2014
EDITED
Try your code:
(defun c:loff ()
  (command "-layer" "OFF" "*" "n" "")
  (princ)
Henrique
Message 5 of 10
mikegera
in reply to: hmsilva
That does not work either.  Is there a way I can save some sort of output file when I run an AutoLISP file so we can see what is going on?
Message 6 of 10
hmsilva
I have edited the previous post, test it...
"Is there a way I can save some sort of output file when I run an AutoLISP file so we can see what is going on?"
In a command call, affter running the code, press F2
For more complex codes, read this Lee Mac Tutorial
HTH
Henrique
Message 7 of 10
mikegera
I see what  I did now.  Wow, what a stupid mistake on my part.  Using "la" instead of "layer".  I am so used to entering "la" at the command line.  The F2 thing helped identify that problem instantly.  Thanks.
An additional "" is required at the end, by the way, or you'll be left hanging.
Thanks.
Message 8 of 10
hmsilva
You're welcome, mikegera
Glad I could help
Henrique
Message 9 of 10
Hallex
In A2014 this would be robust way:
(defun c:loff ()
  (initcommandversion)
  (command "_.-layer" "_OFF" "*" "_N" "")
  (princ)
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 10 of 10
hmsilva
in reply to: Hallex
(defun c:loff ()
  (princ)
Good catch, Hallex!
Henrique
”Boost
