While trying to get everything to work with AutoCAD 2002 and Windows 2000 I
got an strange error message while trying to load an arx from Netware server
Command: arx
Enter an option [?/Load/Unload/Commands/Options]: l
Error code (0x20) The process cannot access the file because it is being
used
by another process.
AcRxDynamicLinker failed to load 'M:\ACAD\PID\WHOHAS.ARX'
C:\Program Files\AutoCAD 2002\acad.exe
Command
With AutoCAD R14 everything works. Is 2002 not supported in Windows 2000
client / Netware environment?
I´m using Microsoft client for Netware. The same happens with every arx I
try to open from the network. Opening from local disk works.
Is there anybody else having the same problem?
Juha Hanninen
