On this the NS list comes up on the dimension all on one line is there a way to get it to come uo on 2 or 3 lines
(setq DM (* rd 2))
(setq DM1 (* rdl 2))
(setq oldtstyle (getvar "textstyle"))
(Setq userfont "GDT_IV50.ttf") ;_ <<<<change this for your textfont
(setvar "textstyle" (cdr (assoc 2 (tblnext "style" t))))
(command "._Style" "" userfont 0.125 1 0 "N" "N")
(COMMAND "_DIMDIAMETER" PT1 pt2)
(setq dia (entlast))
(setq cobj (vlax-ename->vla-object dia))
(setq _str (lambda (num)
(if (eq (type num) 'INT)(itoa num)
(rtos num))))
(setq ns (apply 'strcat (list "n " (_str DM1) " v " "n " (_str DM) " x " (_str dp))))
(vlax-put-property cobj 'TextOverride ns)
@cadking2k5 wrote:(setq ns (apply 'strcat (list "n " (_str DM1) " v " "n " (_str DM) " x " (_str dp))))
Read about when and when not to use apply on your previous thread.
vlax-put-property 'TextOverride srting post # 6 - 7
Keep on coding.
