Visual LISP, AutoLISP and General Customization
(apply 'strcat (list on TWO OR THREE lines
2 REPLIES 2
cadking2k5
458 Views, 2 Replies
On this the NS list comes up on the dimension all on one line is there a way to get it to come uo on 2 or 3 lines
(setq DM (* rd 2))
  (setq DM1 (* rdl 2))
  (setq oldtstyle (getvar "textstyle"))
  (Setq userfont "GDT_IV50.ttf") ;_ <<<<change this for your textfont
  (setvar "textstyle" (cdr (assoc 2 (tblnext "style" t))))
  (command "._Style" "" userfont 0.125 1 0 "N" "N")
  (COMMAND "_DIMDIAMETER" PT1 pt2)
  (setq dia (entlast))
  (setq cobj (vlax-ename->vla-object dia))
  (setq _str (lambda (num)
  (if (eq (type num) 'INT)(itoa num)
     (rtos num))))
(setq ns (apply 'strcat (list "n " (_str DM1) " v " "n " (_str DM) " x " (_str dp))))
  (vlax-put-property cobj 'TextOverride ns)
2 REPLIES 2
pbejse
in reply to: cadking2k5
(setq ns (strcat "n " (_str DM1) "\\X" " v " "n " (_str DM) " x " "\\P" (_str dp)))
\\X -->  Under Dimension Line (one time)
\\P -->  Under  String (every call)
 "<>\\Xbanana\\Pcake\\PHouse"
   12
Banama
  cake
House
pbejse
Read about when and when not to use apply on your previous thread.
vlax-put-property 'TextOverride srting  post # 6 - 7
Keep on coding.
”Boost
