i make 1 dialog box to display all text contens from 1 file *.txt and i just
create 1 button for clear the text in that file to become emty file,
i no ideal how to make the code can yours tell me how to do
Design/Engineering Dept.
hawstom wrote in message
news:4438173.1077654195387.JavaMail.jive@jiveforum1.autodesk.com...
> Note that it is much more efficient to use (cons) and (reverse) than to
use (append). Like this:
> (setq FileName "login.txt")
> (setq FindF(findfile FileName))
> (setq OpenFile(open FindF "r"))
> (while
> (setq ReadLine(read-line OpenFile))
> (setq AppList(cons ReadLine AppList))
> );while
> (close OpenFile)
> (setq AppList (reverse Applist))
