I am looking for a little guidance here. I have this code, that generates a report and saves it to my computer
(c:wd_bompnlr (list 1 1 "" 31 0 "ASC" "c:\\documents and settings\\jlewis\\application data\\autocad electrical 2011\\R18.1\\enu\\support\\user\\bompnl" "c:\\bak" nil))
However, i do not want to save it to my computer i want it inserted into my drawing. Reading a couple of posts here and there, it pointed me to use this command instead
(c:ace_auto_rpt rgfnam firstdnam templatenam)
However, i do not understand what the parameters actually are.
Any help would be very much appreciated!!
Hi manamalewis,
I'm not an "AutoCAD Electrical" guy, but I think not to be possible with the
(c:ace_auto_rpt rgfnam firstdnam templatenam), insert the report into your drawing, it will create a .SET or a .RGF file, was what I understood here...
Maybe with the
(c:wd_bompnlr (list 1 1 "" 31 0 "ASC" "c:\\documents and settings\\jlewis\\application data\\autocad electrical 2011\\R18.\\enu\\support\\user\\bompnl" "c:\\bak" nil))
method, or even with the other one, after creating the report file, and if it is a text file, you can access the file and read / write the report into your dwg...
HTH
Henrique
