I need a LISP program to add a text given by user to all selected text.
in other words:
1- user selects some texts.
2- user give a text to program.
3- Program added this text to all selected text.
selected text: text1, text2, text3,text4,....,textn
given text by user: _xyz
Result:
text1_xyz, text2_xyz, text3_xyz,text4_xyz,....,textn_xyz
Can anybody help me?
Thanks.
Solved by hmsilva. Go to Solution.
maybe something like
(defun c:test (/ ss nstr str itm obj) (vl-load-com) (prompt "\nSelect texts to adda string: ") (if (and (setq ss (ssget "_:L" '((0 . "TEXT")))) (setq nstr (getstring "\nEnter the string to add to the text: ") ) ) (repeat (setq itm (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq itm (1- itm)))) ) (setq str (vla-get-textstring obj)) (vla-put-textstring obj (strcat str nstr)) );; repeat );; if (princ) )
hope that helps
Henrique
anothter
(defun c:Asuf ( / suf ss i e st l) (while (not (progn (setq suf (getstring T "\nEnter string to add: ")) (if ( eq suf "") nil suf )))) (if (setq ss (ssget "_X" '((0 . "*TEXT")))) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i)))) st (cdr (assoc 1 e)) l (assoc -1 e)) (entmod (list (cons 1 (strcat st suf)) l))) )(princ) )
HTH
