is it possible to add field of filename of other drawing for cross reference drawing?
maybe macro, diesel expression or lisp?
see attached file
Yes. One way would be to create a field. Under "Field Catagory", choose "Linked". The only choice below that should be "Hyperlink", click the "Hyperlink" button and pick the desired DWG (or any file type for that matter).
Oops, just realized this is the lisp forum. If you are looking for the field string for use in autolisp code, it's something like this:
%<\AcVar \href "\\server\projects\888\mydirectory\MyDrawingName.dwg##MyDrawingName.dwg#1">%
