New Member
ashfaqhadi
Message 1 of 6 (9,788 Views)
acaddoc.lsp virus
9788 Views, 5 Replies
06-04-2011 07:54 AM
I Have problem when i open autocad 2008 & 2011
the below message appears in the command line.
and when ever i open the drawing from the folder there is automatically a file created in the folder named acaddoc.lsp
can any one help me to remove this threat from the autocad software
i have also re-installed the autocad software but the same problem is repeated again
"AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.; error: LOAD failed: "acadapq"
Command: COMMANDLINE
Command: properties"
Edited by
Discussion_Admin
diagodose2009
Message 2 of 6 (9,779 Views)
Re: acaddoc.lsp virus
06-04-2011 02:25 PM in reply to: ashfaqhadi
see my image yes is a virus
Active Contributor
ehya
Message 3 of 6 (9,705 Views)
06-06-2011 07:28 AM in reply to: ashfaqhadi
To delete the virus,Dwg file is located in the folder, delete files in the LSP.Install the following file.
The command line to run the program "AcdDcCLr" type .
DWG file before starting another, if there are files in the folder, delete them LSP.
Active Contributor
zingero84
Message 4 of 6 (6,998 Views)
05-03-2012 03:48 AM in reply to: ashfaqhadi
Does this fix actually work?
I am having the same problem and it's VERY ANNOYING.  I have no clue how i got this virus because I don't even have time to do anything else at work but work.
All of my drawing file folders have the acaddoc.lsp in them.  If I delete it before opening, they is no virus wanring.  If I leave it there and open it, I get a virus warning.
How do I permanently remove this virus from my computer?
Active Contributor
zingero84
Message 5 of 6 (6,993 Views)
05-03-2012 03:51 AM in reply to: ashfaqhadi
Here is my opening command line info:
Opening an AutoCAD 2004/LT 2004 format file.
Substituting [Arial00000034] for [Myriad Apple].
Resolve Xref "12-013 22x34": X:\12-013 22x34.dwg
"12-013 22x34" loaded.
Resolve Xref "OH ELECT": X:smileysurprised:H ELECT.dwg
"OH ELECT" loaded.
Resolve Xref "12-013 bldg type a": X:\12-013 bldg type a.dwg
"12-013 bldg type a" loaded.
Resolve Xref "12-013 bldg type b": X:\12-013 bldg type b.dwg
"12-013 bldg type b" loaded.
Regenerating layout.
Regenerating model.
C:NEWDATEno function definition: ACET-AUTOLOAD2
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command:
Active Contributor
zingero84
Message 6 of 6 (6,506 Views)
05-23-2012 12:08 PM in reply to: zingero84
I cannot get rid of this virus.
Can someone help me out?
